Gauge interchangeable questions
i have a 93 civic lx 4door with a factory tach on the gauge cluster and was wondering if it will plug and play with my 94 civic dx coupe gauges by swapping the whole cluster?
Well 96-00 clusters can be swapped across the board, so i assume eg clusters are the same? If you already have the cluster, why not swap it and see?
Bipolarcivic, all 92-95' Civics instrument gauge clusters are PLUG and PLAY meaning they are INTERCHANGEABLE.
1. Remove the two upper screws at the gauge bezel.
2. Pry the hazard light button and remove....unplug connector.
3. Carefully pry the long dash bezel and unplug the wire connector at the clock.
4. You will then see 4 screws holding the cluster at each corner. Remove them and disconnect the wire harnesses on the back.
5. Installation is reverse.
thanks for the help i haven't tried it yet been busy and the lx is my dd and the dx is being rebuilt. if i have some down time ill try it and let you know.
Does this mean that a 97-01 CRV cluster will fit in any EK Civic? Someone around here had an image with all the swapable clusters and I can't seem to find it..
just get rid of that crappy dx and lx. they arnt worth a ****. hell, the ex and si get more babes around here than any other carr. or an integra. my boy marcos had a teg. HAD. before he blew it up street racing... stupid.
Crv clusters will fit, if you want kmh and mph, get the acura el cluster, you also get some bonuses:mph is small, and kmh are big, speedo says 140, you got cool jdm amber backlights!! Lol
driftguy2008
Mar 3, 2013 01:56 PM
92-CivicLX
Mar 15, 2009 06:58 PM
