intake manifold problems
Old Jul 3, 2013 | 06:53 PM
GSRCIVIC00's Avatar
Default intake manifold problems
1999 ex manifold different than 1996 hx?
Old Jul 3, 2013 | 07:16 PM
civicexkid1's Avatar
Default Re: intake manifold problems
dont pour gas on an engine bad idea. get a spray bottle and mix water and soap start the car and spary around the intake to see where the leak is coming from, itll help narrow down if it is the egr or if theres another spot. double check and make sure all ports are used up. does your car rev high? on my friends car he left a sensor off his intake mani and started the car and it would rev to 4k then to 1000 and keep doing it until we found the big hole that use to house the sensor.
Old Jul 3, 2013 | 07:22 PM
B_Swapped93's Avatar
Originally Posted by GSRCIVIC00
i pour gasoline on top of the intake and it stalled, so i know that leak is from there.
why couldn't you have just gone and got "carb cleaner" that is beyond stupid to go pouring raw gas on you engine.... even if it wasn't hot yet.
get the correct ITM for the engine you have.
Old Jul 3, 2013 | 08:10 PM
GSRCIVIC00's Avatar
calm down its not like i poured the whole gallon, gas is too expensive these days. the problem is that the itm for the engine has a egr valve, and my harness doesn't have that connection
Old Jul 3, 2013 | 08:11 PM
GSRCIVIC00's Avatar
i only poured a few drops with the engine cold so no problem. all sensors are connected.
sageuvagony
45
Aug 25, 2008 06:27 PM
InkerB2B
Apr 5, 2008 05:03 PM
88crxdxfastwhip
Feb 20, 2007 03:08 AM
trianglegreg
Jan 10, 2006 02:00 PM
