switched auto trans to standard?
Old Jul 3, 2013 | 11:58 AM
NorminN.B.'s Avatar
Default switched auto trans to standard?
My son changed the auto trans on his 99 Civic to a standard. The speedometer on the auto had 2 wires, the standard one has 4 wires on the plug. Any one know which wires to connect on the 4 wire plug to the 2 wire plug. Or maybe have a wiring diagram I could check. I can't seem to find one for the trans speedometer. Thanks....
Old Jul 3, 2013 | 08:04 PM
apexi_rsx's Avatar
Default Re: switched auto trans to standard?
speedos are all the same 4 wire plug on all 92-00 d series transmissions... are u sure ur looking at the right plug? pics may help us
Old Jul 3, 2013 | 10:14 PM
ferio-ichi3's Avatar
Ferio Wdm Edition
Yea, id like to know what plug you are also talking about. i did the swap, only wiring that needs to be done is the clutch interlock switch, cruise control(if you have it) and reverse. The cluster has the same plugs for auto or manual, only plug that wont get used is the green connector for the shift indicator lights..but include pics please
Old Jul 4, 2013 | 03:24 PM
94EG8's Avatar
Seagull Management
The 2 wire plug on the trans is for the backup light switch. Both the automatic and the manual have a three wire VSS for the speedometer.
Old Jul 4, 2013 | 04:05 PM
xile6's Avatar
As said.
3wire speedometer power, ground , signal.
And then backup light 2 wire turns into a ground for the lights.
I don't know of a 4 wire plug beside the o2 sensor.
Old Jul 8, 2013 | 07:15 AM
NorminN.B.'s Avatar
Thanks for the reply's. I'm only going with what he told me. I will have to get him to recheck it. Thanks.........He just got back to me, my fault, he has a 99 Accord, not a Civic. Sorry.........
helpmeplease
Engine Management and Tuning
May 9, 2011 12:44 PM
01ethansh
12
Oct 18, 2008 06:29 AM
s73
Jan 7, 2005 12:12 PM
s73
Jan 7, 2005 09:47 AM
