My 96 D16Y8 non-vtech manual making strange noises at idle
Old Jul 3, 2013 | 05:10 AM
Diceclay's Avatar
Default My 96 D16Y8 non-vtech manual making strange noises at idle
My Aussie 96 D16Y8 non-vtec manual is making strange noises at idle and also when coming to complete stop.
At Idle and the manual transmission in neutral and the clutch out the car is making a noise that sounds almost like a "diesel motor type noise". After I press in the clutch, the noise goes away. Could it be a diff?
Also the second weird noise is when I am coming to a slow complete stop or very slowing taking off, i hear what is best described as a "ratatatat" which increases or decreases according to the RPM's. After take off I cant seem to hear it. Sorry for the rough descriptions of the noise but the best description that i can come up with in words.
The car seems to go fine though. I have had a suggestion that its a bearing in the clutch that needs replacing / which obviously also may mean a new clutch.
The car is stock except for an after market heavy duty clutch fitted a few years back which was the 2nd clutch used, the first being the stock one from new. No other mods and the car has done approximately 275,000 klms. I dont track it but I do give it spirited road driving.
One other quick question is if the clutch needs replacing, which clutch would people recommend? Exedy etc?
Thanks in advance for your help and wisdom.
Old Jul 3, 2013 | 05:17 AM
grumblemarc's Avatar
The Grumpiest
Default Re: My 96 D16Y8 non-vtech manual making strange noises at idle
How is your Y8 not VTEC?
Your description isn't doing it. Post a video.
Old Jul 3, 2013 | 05:27 AM
Diceclay's Avatar
Sorry, My bad it looks like the engine is a D16Y4.
Similar to this pic but without the cold air intake.
Last edited by Diceclay; Jul 3, 2013 at 05:30 AM. Reason: http://i88.photobucket.com/albums/k177/chrisgiovine/5.jpg
Old Jul 3, 2013 | 05:29 AM
kyden's Avatar
input shaft bearing and/or other internal bearing in the transmission.
Old Jul 3, 2013 | 05:36 AM
Diceclay's Avatar
I stand corrected grumblemarc, thank you. . Sorry about that.
Thanks Kyden so would that mean a tranny rebuild or just change those bearings? Also as the tranny may have to be dropped to get in to change those bearings would a new clutch be in the mix to do whilst the tranny is down? Sorry for the many questions.
Old Jul 3, 2013 | 06:48 AM
kyden's Avatar
you have to drop the transmission to do so. you would only have to change the bearings. you don't know which ones until you pull the transmission apart though.
I would probably do the clutch too, might as well while it is out of the car.
Old Jul 4, 2013 | 05:19 PM
MikesEJ1's Avatar
My tranny had the same problem,its quite common
Old Jul 16, 2013 | 12:34 AM
Diceclay's Avatar
Hey guys sorry to bump this thread but you were all absolutely right, it was the Input shaft bearing and its getting looked at as we speak.
Thanks again.
Bheriya
Apr 6, 2018 05:39 AM
WorkHardZ
Transmission & Drivetrain
May 18, 2016 09:17 PM
bonestock db8
Sep 24, 2011 03:16 PM
jimmy310
11
Nov 15, 2007 12:54 PM
MrKrizzle
Mar 5, 2007 06:51 AM
