Where to find flared connectors/flange?
I have a customer who brought in a car for a bolt on custom exhaust.He had told me the stock system had vband connectors so I loaded up on those.We got car in,took off bumper and dropped the whole exhaust system.Its actually running these flared vband looking fanges.
I have been looking for a place all day long to order some but no luck.Cant seem to get a name for them either.Some places had them as flared reducers others as marmon fange and also flared connectors.
Cutting off the factory ends and welding on a common vband is NOT an option.Let me know if you guys know where to get some stainess ones,thanks.
this is what ive make for a Peugeot exhaust system that comes with some type of vband too.. repaired it.
Used something like this:
http://www.steel-pipecn.es/product/6-2b.jpg
I hope this help!.
I hope this help!.
cut off both sides of that and weld on the vbands you loaded up on.
nvm just read the bottom of your post below the picture. flare it yourself in a press with a mandrel made to the same specs you need to seal properly.
Transition cone wont work for that, they are typically 35 degrees. That's a 60 degree flare die atleast. It can also be made from a 45 degree flare die then flipping the die over to the flat face and pushing a bit further.
*Boostwerks*
Welding / Fabrication
Jun 19, 2006 11:22 AM
david@didrace.com
Dec 7, 2004 06:01 AM
