wagovan random code 16?
I was driving around yesterday and my engine light came on, I noticed the car ran as if one if my wheels was out of balance. When I pulled over I let it idle then I reved it up a bit, it sounds as if it's running on 3 cylinders.
What could cause this code? My main relay looks good
Check your actual injectors, if those go south I believe that will throw a code 16 as well. (If you have MPFI the not running on all cylinders would seem to indicate this as well.)
I checked the resistance between the two terminals on my injectors and they were all either 3.1 or 3 ohms, where would I go from here?
Service manual pages for this code
http://www.clubcivic.com/board/showp...63&postcount=5
bgcrx
Feb 21, 2008 07:24 PM
