input on wheelie/traction bars
im looking for some input on wheelie/traction bars..im thinking of doing a setup with 2 air cylinders that can be actived at the line to put presure on the rear and keep the from pushed down and elminate any rear squat and deactivate at a given mph...our local track is no good for prep..they only prep the first 60ft and even then its not often, the car is a 99si with 700whp ,24.5x9x13 the best 60ft i can get is 1.7x ...would the wheelie bar setup really help with 60fts and 330fts?....any input would be great
how much pressure do you run in your front slicks ?
how old are your slicks ?
have you had an alignment done recently ?
what is your launch rpm ?
how much boost are you building on the launch limiter ?
open diff or lsd ?
what shock/springs on front ?
are your suspension bushings shot ?
do you run a traction bar up front ?
open diff or lsd ?
how much pressure do you run in your front slicks ? anyweres from 6-10 psi
how old are your slicks ? new..maybe 6 runs on them
have you had an alignment done recently ? yes
what is your launch rpm ? 5-7k tryed everyweres in between
how much boost are you building on the launch limiter ? tryed differnt boosts...3-4psi is the best i got for 60fts
open diff or lsd ? lsd
what shock/springs on front ? f&f type 2
are your suspension bushings shot ? front end is all tight
do you run a traction bar up front ? yes ketuned
try this for a base point.
7 psi in sicks
7000 launch rpm
8psi boost launch boost
also, i forgot to ask, but what width wheel are you running, and do you have rim screws or beadlocks ?
7 psi in sicks
7000 launch rpm
wleach11
Jun 21, 2005 12:12 AM
