FS: Used Synapse Synchronic BOV
Old Jul 1, 2013 | 06:44 AM
FkingSUV's Avatar
Default FS: Used Synapse Synchronic BOV
Used Synapse Synchronic BOV - Includes Aluminum flange and Boost pipe - $150 + Shipping + PP Fees
Synchronic BOV is the fast-acting design that functions as a blow-off, diverter (DV)/bypass and even a pop-off valve. The patented (6,863,260) design eliminates the diaphragm with a multi-tier piston actuator that self-centers under pressure. This design is intended to significantly reduce or eliminate compressor surge and will not leak boost.
SB001 is a universal, pull-type BOV design that eliminates leaking by seating the valve more as boost pressure increases. Each assembly is pressure tested to 100psi prior to leaving the factory.
Old Jul 3, 2013 | 05:00 AM
FkingSUV's Avatar
Default Re: FS: Synapse Synchronic BOV
TTT
Old Jul 26, 2013 | 04:42 AM
FkingSUV's Avatar
Default Re: FS: Used Synapse Synchronic BOV
Quality stuff here.
Bump!
FkingSUV
Jul 17, 2013 10:24 AM
88 EF Hatch
Aug 1, 2011 02:23 PM
Synapse
Sep 17, 2006 08:27 PM
BlackB18CTeg
Oct 4, 2003 11:16 AM
nd8ch
Dec 4, 2002 02:29 PM
