What does this plug go to??
I recently purchased a 99 si shell that I'm rebuilding. There is a orange plug under the back seat on the drivers side that is not connected to anything. On the passenger side in the same spot it looks like a plug was in the same spot as the driver side but nothing is there. I put a picture below. What do these go to?? Thank you!!
I looove how the solution to all braking things is a 4040 valve.
the USDM 99 SI never came equipped with ABS, the Canadian ones did on the other hand.
It's easier during the manufacturing process to run it and not screw with the harness, not to mention cheaper.
