EX vs DX engine harness (DX car)
Old Jun 29, 2013 | 05:18 AM
skill178's Avatar
Default EX vs DX engine harness (DX car)
okay, so I recently purchased a DX hatch 93' that had a d16z6 in it but the idiots were still running the D15 ecu and there are no vtec wires run. he blew a hole in the side of the block and I picked up another Z6 with the engine harness attached,
can I just plug and play the EX harness, only difference im aware of is the vtec wires, if everything else plugs fine can I just run the wires from the strut tower connection? or are the harnesses different pin outs?
Old Jun 29, 2013 | 05:23 AM
grumblemarc's Avatar
The Grumpiest
Default Re: EX vs DX engine harness (DX car)
Use the harness in the car. Run your VTEC wires. Look up how to do it.
Old Jun 29, 2013 | 05:40 AM
frost_white_ej1's Avatar
either route with the harness you will have to wire and add pin to the ecu harness so it up to you just make sure to use a p28 instead of that d15 ecu.
Posted from Honda-tech.com App for Android
Old Jun 29, 2013 | 05:44 AM
skill178's Avatar
yes, I have a p28, I was hoping to use the Z6 harness that runs from the strut tower so I wouldn't have to run the wires from the solenoid, will the Z6 main connections plug into the DX
Old Jun 29, 2013 | 05:46 AM
The Grumpiest
It's not that hard. Look up how it's done.
Old Jun 29, 2013 | 06:25 AM
skill178's Avatar
I know it's not hard, I've wired in a z6 to an ef hatch
But the wires always look like ****. The z6 has them ran to the tower and I would rather run the wire from the tower to the ecu if everything else won't have to be repinned , sorry if didn't make that clear in the first post thanks
mike93eh2
Apr 23, 2008 06:13 PM
Kyles ej1
Aug 27, 2005 09:15 PM
capbyrd
Oct 14, 2004 12:34 PM
johnzm
May 31, 2004 11:49 AM
Dancing is Forbidden
Dec 9, 2002 05:45 AM
