b16a2 swap question about Intake Manifold
Old Jun 28, 2013 | 05:27 PM
jesse.pulido's Avatar
Default b16a2 swap question about Intake Manifold
This is my pr3-4 b16 intake manifold with obdo injectors.
My question is, if I change the injectors to obd1 can I use it on my
b16 swap into my 1996 ek ? my motor is a jdm b16, with a p28 chipped ecu
or will I have to buy a b16a2 p30 intake manifold? im on a budget ?
[IMG][/IMG]
Old Jun 28, 2013 | 07:50 PM
DR_RHD_EG6's Avatar
Default Re: b16a2 swap question about Intake Manifold
I would say yes you can change it. make sure you can do your wiring correct. if your swaping it into an ek mine as well drop in obd2 injectors :D! so you wont have to cut your injecto plugs and put obd1 plugs..
ps, i just had to do the same thing but insted i put obd2 f-series injectors on my ls manifold going into my eg coupe.
Old Jun 29, 2013 | 01:00 AM
Lol you confused me bro so put in obd2 injectors not obd1 in the manifold and I can use the manifold for my 96 ek ... Is their a certain way I have to wire it up since I'm not using the obd2 manifold?
Old Jun 29, 2013 | 04:57 AM
nealnanoHX's Avatar
I would go with a P30 intake, it flows a bit better and has a cleaner look since it does not have all that extra crap on it. No need for the fast idle valve ect.
K-G
Oct 2, 2018 04:15 AM
sive
May 17, 2012 12:42 PM
go2sleep
Nov 3, 2005 05:15 PM
nikitad
Dec 22, 2004 12:22 PM
