Honda CR-V & Element 2WD & 4WD Element & CR-V
having trouble putting car into gear
Old Jun 28, 2013 | 01:23 PM
slowesteg's Avatar
Default having trouble putting car into gear
i had window problems (off track) and when i went to go fix it, i had problems with the power windows working for a bit then shuts off (only driver side) so i wiggled the harness (door/fender harness) worked for like 5 min and then completely shuts off all power to the driver front door. i went to go start the car up, car wouldnt start (like low battery), waited for a bit and try to start the car again and starts right back up like normal but can not put it into gear. car ran fine/went into gear before all this window crap.
i also did notice that when i turn the car to the on position only the battery light comes on no check engine light. also there is no rpm's when car is started dead at 0 rpms. also when the car is started and driver side door is open, sometimes that beeping noise comes on but if i keep wiggling that harness itll shut off (should only beep when car is on the ON position only not when started).
what could be my problem? i pulled the complete dash out already tried to wiggle the whole inside harness but still cant get the car to go into gear.
Old Jun 28, 2013 | 01:56 PM
Sticker Bomb's Avatar
Default Re: having trouble putting car into gear
You have a ground wire issue somewhere most likely. Check all the grounds the go to the engine, tranny, body, battery.
Old Jun 28, 2013 | 02:57 PM
slowesteg's Avatar
i pulled that harness out (at the door) and found a few wires that were pulled out/broken off. but why would it cause it not go into gear? cause thats all i touched
anyone selling a harness? i need the harness that goes thru the driver door into the interior (floor harness???)
Old Jun 28, 2013 | 03:49 PM
I don't know why it would unless there is a safety that will not let it go into gear if it thinks the door is open. I really don't know
Jay Pafford
Dec 19, 2017 10:03 PM
beans04
Nov 15, 2008 12:23 PM
mike03,95civic
18
Feb 25, 2008 06:04 PM
coronadrinker
May 28, 2007 02:47 PM
Forty04
10
Dec 26, 2006 07:35 AM
