Honda CR-V & Element 2WD & 4WD Element & CR-V
Intermittent A/C
Old Jun 28, 2013 | 08:25 AM
vikingslayer's Avatar
Default Intermittent A/C
My '97 Crv is blowing cold air intermittently. It is really nice and cold when it works, and my refrigerant pressure is fine. I have noticed that when it blows warm, there is a chug-a-chuga noise coming from either compressor or clutch, can't tell for sure which.
Could this be a problem with the compressor? Would it blow cold at all if the compressor was blown, or is it the clutch that is acting up?
Thank you in advance for your excellent reply.
Old Jun 28, 2013 | 10:39 AM
Phantom240's Avatar
Default Re: Intermittent A/C
Does vehicle speed affect the intermittent cooling?
Old Jun 28, 2013 | 11:13 AM
Does not seem to.
Old Jun 28, 2013 | 11:21 AM
Sticker Bomb's Avatar
It's most likely the clutch. If the compressor was not working, you would have no A/C at all.
Old Jun 28, 2013 | 01:23 PM
Phantom240's Avatar
Also, if it was intermittent at low speeds but cold at high speeds, it would likely be fan related.
Old Jun 28, 2013 | 05:31 PM
Which fan?
Old Jun 29, 2013 | 01:45 AM
Frozen E's Avatar
H-T White Ops
Originally Posted by vikingslayer
Which fan?
Condenser fan. At high speed the air going over the condenser and radiator is enough to keep pressures low enough. When you slow down that air movement goes down, causing head pressures to go up, possibly opening the high pressure switch, causing the compressor clutch to disengage. It's a safety device.
With the car parked and idling, check to make sure that the condenser fan actually comes on. If not, there's your problem. Also, if the condenser fan isn't coming on, there's no way to properly check to see if the pressures are right.
If you have a condenser fan that's not coming on, and you checked pressures and determined they were "good", I guarantee you that your charge is way off.
Old Jun 29, 2013 | 02:11 PM
Phantom240's Avatar
Either fan could be culprit. My radiator fan wasn't spinning, and my condenser fan was pushing instead of pulling. Needless to say, I had no A/C at idle.
Old Jul 1, 2013 | 12:02 AM
Frozen E's Avatar
H-T White Ops
Is the CRV setup like the Element where the condenser and radiator are sandwiched with the condenser in front, or is it like the Civic where both are half size and sit next to each other?
Old Jul 1, 2013 | 08:19 AM
Phantom240's Avatar
They're sandwiched, full size.
Old Jul 11, 2013 | 03:54 PM
KrazyRdR83's Avatar
Wonder if the fan is my issue then, I don't have cold a/c, it'll take a few hours for it to get really cold. When it's not so hot out or early morning it's cooler, but lately it's been 100 here & it barely blows cold. The clutch comes on, I checked the freon, was low, added some. Was going to just get the a/c serviced but being it's colder in cooler temps has me thinking it's something else
agavenda30
Jul 7, 2009 12:40 PM
xpdude
Jul 6, 2009 06:46 PM
LeniX
Dec 15, 2008 12:14 PM
sj993
Apr 18, 2006 08:12 AM
devilpuppy
Jun 11, 2005 08:34 AM
