Starter problems
Jus put in a new starter on my h22 and for some reason it's getting constant power. Like as soon s I re connect my battery the starter just starts spinning. Then I take the ground off the battery and it stops. I do have a good ground connected to the starter. Any help is appreciated.
When the power isn't connected to the battery then everything is grounded. But when the power is connected then everything is getting power
With key off.Remove power wire to starter, reconnect battery, test if you get battery voltage at solenoid signal wire. If you do, check relay and wires. If no voltage to solenoid, test solenoid if its stuck or working. When the starter spins, does it engage and spin the engine at the same time?
