01 accord g23 swap shift cables with h trans?
Old Jun 26, 2013 | 02:18 PM
G23accord11's Avatar
Default 01 accord g23 swap shift cables with h trans?
I'm almost done buildings motor it's a h22a4 head ported with 5 angle full skunk 2 pro valve train and cams f23a1 block deleted balance shaft block gaurd bore .05 over low comp my trans is h22a LSDy question and haven't thought about is do I need a prelude shift box and cables or will my be fine.
Old Jun 27, 2013 | 06:11 PM
Default Re: 01 accord g23 swap shift cables with h trans?
Bump
Old Jun 27, 2013 | 06:17 PM
DeadlockRiff's Avatar
you can use either the Accord shifter + accord cables or prelude shifter with prelude cables.
It's irrelevant to which you use as far as functionality as long as they're a matching set.
pcguy760
Oct 14, 2013 02:32 PM
99blackdc2
Sep 11, 2007 06:37 PM
cpforyou
Dec 5, 2005 12:26 AM
RUBZERK
Mar 30, 2004 11:21 AM
