D16y8 pm7 pistons
Old Jun 26, 2013 | 09:04 AM
pelayo114's Avatar
Default D16y8 pm7 pistons
Anyone here have this setup? Stock crank, stock head, stock cam. I'm about to go for this setup as soon as i can source a crank(spun a rod bearing and damaged the journal) and I'll be running a cometic 2.5mm head gasket. Just wondering if anyone has tried his and how reliable it is. Anyone's input? (May be in the wrong forum section)
Old Jun 26, 2013 | 09:06 AM
grumblemarc's Avatar
The Grumpiest
Default Re: D16y8 pm7 pistons
Reliable? In terms of what?
I type your thread title into Google and I get this.
https://www.google.com/webhp?sourcei...w=1828&bih=862
Don't tell me none of those threads answers your questions.
Here's another link you need to get familiar with.
Here's a quote:
the p29/pm7 pistons will give you a 12.6:1 compression ratio in a stock d16y8 with a stock headgasket. that compression is kind of high for a daily driver.
Old Jun 26, 2013 | 10:09 PM
pelayo114's Avatar
I have already looked through all of those threads and posts prior to creating this thread. Couldn't find a single thing about maybe the HG being too thick or compression being too high for 91 octane pump gas. This is why i was asking if anyone had done it to hear from them instead of people just posting their theories or information based on the compression calculators.
Old Jun 27, 2013 | 03:33 AM
The Grumpiest
You didn't ask if the headgasket was too thick. You only mentioned what headgasket you were going to use. You asked if it was going to be reliable. If you're going to NOT use the standard parts when doing this mod and you DON'T know how to calculate compression then just stop. If you don't want to use the compression calculators as a tool to inform your judgement then stop. If you don't know if compression is going to be unsafe for pump gas then stop.
Because when I put your info into the calculator I get 10.9:1 compression ratio. The Zeal calc seems to estimate pretty well if you know what you're doing. So from what I see doing this doesn't net you too much compression over stock (9.60:1). So my question to you is why? If you're scared of high compression then leave the car alone.
Why you people keep trying to build N/A D-series is beyond me. It is an utter waste of time.
Old Jun 27, 2013 | 04:23 AM
The Grumpiest
Oh. And here's a link on the link on the limits of 91 octane as it pertains to compression.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/91-octane-compression-limit-2858823/
Please don't tell me with a straight face that you searched.
And I hope you plan on getting this tuned.
Vladglad
Mar 13, 2014 01:54 PM
steronz
Mar 21, 2005 03:29 PM
addictionguy
Jan 26, 2004 07:36 PM
d16y8EL
Jan 4, 2004 08:20 PM
GummiBeer
17
Mar 9, 2003 09:30 PM
