TW 1995 CIVIC EX ABS 5SPD FULL POWER
Old Jun 25, 2013 | 11:18 PM
JDM_JNKY's Avatar
Default SOLD: 1995 CIVIC EX ABS 5SPD FULL POWER
SOLD
TESTING WATERS IF TRADED - WOULDN'T MIND TRADING FOR A MANUAL 5/6SPD BLACK WHITE OR RED MK4 JETTA
CONTACT: JOEL 909 728 9967
VEHICLE: 1995 HONDA CIVIC EX 5SPD 220K CLEAN TITLE G71-P ISLE GREEN PEARL
CONS:
ODOMETER BROKE INBETWEEN OWNERS, REPAIR AT NEXT INSPECTION DOCUMENTED AS POTENTIAL ROLL BACK - OCCURED AT 180K
NORMAL BUT CLEAN INTERIOR WEAR
NORMAL PAINT FADE
NORMAL DINGS 18YR OLD CAR
DENTS - ALL DOORS BELOW MOLDING PROTECTOR
TOTAL LABOR: 1825.00 | TOTAL PARTS: 3089.00 | TOTAL VALUE: 4900.00+ in new parts and labor
ASKING PRICE: NOW $2200 WAS $2800
CAR WAS AUTOMATIC, PROFESSIONALLY CONVERTED TO STICK/5SPD AND SMOGGED LEGALLY
ENGINE
- Head d16z6 Vtec resurfaced, new oem valve seals, valve adjustment, oem cam seals, spark plug seals, valve cover gasket, TB gasket, oem headgasket,
- New primary O2 sensor
- New 4-2-1 Exhaust Manifold ( improved engine response, torque, and top end engine performance )
- NGK spark plugs and wires ( improved ignition conductivity, improving fuel economy, and engine performance )
- Thermal intake manifold gasket ( replaces oem gasket, reduces intake air temps, improves heat transfer, and lasts longer )
- Distributor ( replaced ignition coil, cap, and rotor, o-ring )
- ARP headstuds ( replaces oem headstuds, they never need to be removed or replaced like oem, the prevent head lifting at high rpm driving. great for nitrous, turbo, and supercharger applications )
- Block d16z6 ( replaced oil pan gasket, timing belt, water pump, tensioner, front main seal, and rear main seal )
DRIVETRAIN
- Rebuilt s20 b000 transmission ( all new bearings, all new seals internal and external, all new brass synchros w/ synchro springs, friction rings, )
- New XTD OEM stage clutch with full face disc
- New XTD 12lb flywheel
- SS steel braided clutch line
- New clutch slave
- Energy Suspension Stabilizer rod bushing
- GSR shifter new change lever ball and seal
- ITR blk/ylw stitch shift boot
- New starter
- New Driver Axle
- Psngr POLY filled TQ mount
- Innovative Steel Auto-Manual Trans Mount
- Energy Suspension GSR Driver Mount insert
COOLING
- New T- sat w/ gasket
- Dual core radiator
- slim fan ( improved cooling, reduced engine temps and amp drops throughout system )
WHEELS/TIRES
- Bring your own, si's sold. Currently on borrowed wheels.
A/C - RECHARGED BLOWS COLD
- New compressor
- New condenser
- New receiver drier
- New expansion valve
UPDATED IMAGES:
Old Jun 25, 2013 | 11:55 PM
M0N0C4M's Avatar
Default Re: TW 1995 CIVIC EX ABS 5SPD FULL POWER
Old Jun 26, 2013 | 12:35 AM
JDM_JNKY's Avatar
thanks
Old Jun 26, 2013 | 08:21 AM
93geezr's Avatar
"In it for pics bump to the top cause I need a daily" bump. Yah.
Old Jun 26, 2013 | 02:08 PM
4drferio's Avatar
bumppp great guy =]
Old Jun 26, 2013 | 02:18 PM
aftermath1312's Avatar
Always selling good stuff
Old Jun 26, 2013 | 03:27 PM
JDMKAY's Avatar
Old Jun 26, 2013 | 03:58 PM
Mashi2Choco's Avatar
Old Jun 27, 2013 | 12:23 AM
JDM_JNKY's Avatar
now has picturez
Old Jun 27, 2013 | 09:20 AM
Cargo636's Avatar
Willing to add cash and trade for '98 dc2?
Pm me if interested.
You've seen and worked on my car ;-)
Old Jun 27, 2013 | 10:06 AM
xELxCHIDOx's Avatar
Toppppp
Old Jun 27, 2013 | 10:13 AM
JDM_JNKY's Avatar
LOL no thanks, only because I'm running from cars I can easily, and heavily modify. I prefer cash to finish my subie, or a Jetta to give my wife a pleasureable DD.
Old Jun 27, 2013 | 10:28 AM
xELxCHIDOx's Avatar
Bumppp
Old Jul 1, 2013 | 03:53 PM
wutthebun's Avatar
damn that's cheap for all that work!
Old Jul 1, 2013 | 08:54 PM
JDM_JNKY's Avatar
Originally Posted by xELxCHIDOx
Bumppp
LOL and it's still not sold? obviously not......
Thanks sir!
Old Jul 5, 2013 | 07:45 AM
JDM_JNKY's Avatar
Old Jul 29, 2013 | 04:26 PM
JDM_JNKY's Avatar
keep this alive...for sale / for trade
Old Jul 29, 2013 | 07:53 PM
M0N0C4M's Avatar
Old Aug 7, 2013 | 10:41 AM
JDM_JNKY's Avatar
Meoooooow
Old Aug 10, 2013 | 09:15 AM
JDM_JNKY's Avatar
yeeeeeeeeeeeee
Old Aug 12, 2013 | 12:32 AM
JDMKAY's Avatar
Trade for flatscreens? Lol
Old Aug 14, 2013 | 08:08 PM
JDM_JNKY's Avatar
Yeah a 103'" TV always wanted.
Updated. Thank You.
Old Aug 15, 2013 | 11:19 AM
monsterk20's Avatar
nice dd...upupupupup
Old Aug 15, 2013 | 11:22 AM
wutthebun's Avatar
i got some stock 13s with tires if u need em
Old Aug 15, 2013 | 02:04 PM
M0N0C4M's Avatar
Eh 9!
