Rear Deck Removal
Old Jun 25, 2013 | 07:14 PM
TheToaster's Avatar
Default Rear Deck Removal
Hello.
I want to remove the deck and move the speakers to the lower hole on the sides.
If I remove it and the angles reinforcement will the back be overly susceptible to twisting?
I was thinking of welding a bar across the back closer to the window to open up the back, seem plausible?
Also thinking of adding a main hoop, harness bar, and A Frame.
Also thinking about welding plates between the bar and the car frame? Any input on this?
Thanks!
Old Jul 2, 2013 | 07:24 PM
TheToaster's Avatar
Default Re: Rear Deck Removal
Has anyone removed the rear deck or relocated the speakers to those holes?
Old Jul 3, 2013 | 05:21 AM
HellaFab's Avatar
removing the rear deck should only be done on a car with a roll cage. that metal will keep your car stiff from rotation (i.e. if you were to jack the car up.) think of it as a "next level" miracle X brace.
GraphiteMW
Dec 26, 2006 10:18 AM
92LudeSI
Jul 27, 2004 09:08 AM
daewonder.
Aug 22, 2003 05:12 AM
stillencivic
Audio / Security / Video
Apr 16, 2003 05:24 AM
asar
Oct 3, 2001 11:18 PM
