idle problem
Old Jun 25, 2013 | 06:22 PM
Nick Cello's Avatar
Icon2 idle problem
hey guys i have a b18b1 obd1 swapped ef hatch dx and when i first start it in the morning it idles at a crazy 2500 rpm and i dont know how to fix it any ideas? thanks in advance
Old Jun 25, 2013 | 06:31 PM
silkypillows's Avatar
Default Re: idle problem
does it idle normal when at operating temp?
Old Jun 25, 2013 | 07:55 PM
Nick Cello's Avatar
yes sir
Old Jun 25, 2013 | 08:36 PM
the problem most likely lies in your cold fast idle valve (FITV) it's most likely out of spec, but could simply not have coolant enough coolant passing through it, due to low coolant or air in the cooling system.
I believe there are sticky threads on the procedure to adjust the FITV, but it's pretty straight forward. opening up diaphragm cover and turn clockwise. until cold fast idle speed is achieved - should be around 1.5k, i believe. engine should cold when attempted to start after adjusting.
95Sedan
Oct 11, 2013 03:29 PM
KimvdLinde
Jun 29, 2013 01:40 PM
mkrieger500
Mar 2, 2011 12:53 PM
jdmgeezer
Dec 9, 2007 11:23 PM
village_idiot
Oct 30, 2004 05:12 AM
