Kaizenspeed Rear Trailing Arm w/ Staging Brake
Introducing the Kaizenspeed Rear Trailing Arm Complete Kit!
This kit serves to reduce weight in the most important area of a race car (unsprung and in the rear) while maintaining the use of your OEM shock and lower control arm. It features an adjustable wheelbase with a design optimized for lowered cars. This is the necessary next step for FWD Honda Drag Racers. It completely replaces the entire rear trailing arm assembly for 94-00 Integra, and 92-00 Civic and allows for an extended wheelbase up to two inches while reducing weight by over 50 pounds!
Product Features:
- 50 lbs lighter than stock (lighter than other similar available kits)
- Extends the wheelbase up to 2” (adjustable)
- Maintains the use of OEM shock and lower control arm.
- Toe adjustment and camber adjustment built-in
- Lightweight steel rotors less than .200” thick
- Rear speed sensor enabled
- Available in 5 lug
- Meets class rules for various sanctioned events (with optional add-on)
- FOR OFF-ROAD USE ONLY
Made entirely from Chromoly and aluminum for the best strength/weight ratio
Each kit includes: A set of rear trailing arms with lightweight spindle, lightweight brake rotors, brake calipers, brake pads, stainless brake lines, toe adjuster, camber adjuster, and all necessary hardware! Ready to bolt on. ***Must be used with rear OEM Disc Hubs***
Optional Add-ons:
- Bracket for OEM Magnetic ABS Sensor
- Bracket for Xenocron Hall Effect Speed Sensor
- Optional Toe Link Bracket (to meet class rules where all OEM points required)
Products were fully tested, engineered and are ready and in stock to ship now worldwide!
Contact your local favorite parts shop to get yours today or order online at:
www.kstuned.com (west coast)
www.xenocron.com (east coast)
Product Features:
Optional Add-ons:
http://www.xenocron.com/rear-trailin...eed-p-886.html
Its about 3mm longer than stock wheelbase at a minimum...up to 2"
Farlander
Mar 2, 2011 05:13 PM
