distributor timing
Old Jun 24, 2013 | 09:13 PM
waynesumner's Avatar
Default distributor timing
I replaced my distributor and my car will not start now how can I time it with out a timing light or at least get the car to run
Old Jun 24, 2013 | 09:43 PM
Ryan Lwin's Avatar
Default Re: distributor timing
You cannot set timing unless car run. Car has to be running in any shape or form. Even if it's crap idle, it has to be running. Otherwise, there is no timing. Timing = synchronized time of the pistons firing. Pistons only fire when engine is running.
You said in your other thread that there's air and fuel? How do you know? Did you only check if the fuel pump primed? Do you even know if the injectors are spraying? Do you know if throttle body has some opening to give enough air to start the car? I suggest you stop creating multiple threads for the same problem.
Old Jun 24, 2013 | 10:11 PM
I do have spark I have fuel and I have air! my spark wires are ordered wrong so ill see whats up tomarrow in the mean time how would you set timing with out a timing light
Old Jun 24, 2013 | 11:07 PM
Ryan Lwin's Avatar
You don't. You pay the shop $70 to do it or buy a gun.
Old Jun 25, 2013 | 03:47 PM
well i got it running and now i suppose it needs a timing. distributor seal was thrashed letting out all compression
Old Jun 25, 2013 | 04:19 PM
grumblemarc's Avatar
The Grumpiest
Never heard that one before.
Old Jun 25, 2013 | 04:23 PM
idk the seal was ripped an when i would it was turning over oil would spill out and just keep turning over not start changed the seal an it started
Old Jun 25, 2013 | 04:25 PM
The Grumpiest
Hm. I wonder in all that time how THAT detail went unnoticed?
redyute's Avatar
lol Ur killin me grumble
Old Jun 25, 2013 | 04:28 PM
The Grumpiest
What? I haven't.
Old Jun 25, 2013 | 04:38 PM
What? I haven't.
never even thought about it and never even knew until i seen some diagram that said REPLACE O RING
Old Jun 25, 2013 | 05:02 PM
Ryan Lwin's Avatar
When you took the distributor apart to test the ignition coil, you didn't see the oil? @_@
Old Jun 25, 2013 | 08:34 PM
yea there was some oil but when I took the distributor off it came out of the engine. any ideas why my CEL would come on?
Old Jun 26, 2013 | 10:57 AM
pulled erroe code 12 EGR on my 94 civic ex vtec. wheres the EGR located?
Old Jun 26, 2013 | 06:48 PM
B(eighteen)C's Avatar
Maybe you've got the wrong code.
Old Jun 26, 2013 | 08:09 PM
you tell me.
Old Jun 27, 2013 | 05:33 AM
kyden's Avatar
that looks like a 3 to me.
Old Jun 27, 2013 | 05:42 AM
The Grumpiest
Agreed. Not hard to read that. And see how we're in the "distributor timing" thread you made and checking for unrelated codes? Confusing.
Originally Posted by Syndacate
If your SRS light isn't on while the car is running, don't worry about it.
I don't recall 100% but I'm pretty sure the SRS light blinks sometimes while you have the service connector jumped (to check codes) - just ignore it - as long as it's not throwing a light while it's on.
Just ignore the SRS light for now - as long as it's not on while the car's running I wouldn't worry about it worth of dick. Like I said, I recall it flashing while the 2p service connector is jumped sometimes. Though I don't remember specifically.
You are jumping the 2P connector though, and not the 3p one, right?
91smashbox
Feb 11, 2008 01:33 PM
CaptivaBlue
Dec 3, 2005 01:12 PM
tc
Sep 21, 2003 06:42 PM
you2envious
Jun 5, 2002 07:50 PM
maggsgsr
Apr 1, 2002 09:46 AM
