Car struggles to start. Ignition switch?
Old Jun 24, 2013 | 06:41 PM
jdm_ek_noob's Avatar
Default Car struggles to start. Ignition switch?
Hello HT. For awhile now, my car has been struggling to turn on the first time I turn the key. The car starts up, but dies right after. Sometimes, the car dies out of nowhere. My starter was replaced a month or two ago so I don't suspect that to be the problem. Also, whenever I hit a hard bump or pothole, the car dies after a few seconds of impact.
So the reason why I suspect my ignition switch is because the car doesn't turn off when I hold the key "forward". For example:Clutch is in, I turn on the car, clutch is out, but I don't take off my hand from they key. As soon as I let go of the key, the car dies. This doesn't always happens but it usually does. Could this be a bad ignition switch?
Oh, and the lights from my cluster stay on when the key is in. Any input will be greatly appreciated. It's a 1999 ek with a d16y8 engine.
Old Jun 24, 2013 | 09:59 PM
Ryan Lwin's Avatar
Default Re: Car struggles to start. Ignition switch?
Did you try pressing the gas paddle instead of holding the key when the car starts?
Old Jun 25, 2013 | 12:50 AM
Buckshot870's Avatar
Check your battery terminals for tweaks, rips, or if they are even on correctly.
Old Jun 25, 2013 | 08:57 AM
mikekh10a's Avatar
If you suspect it being the ignition switch, bring it to a honda dealership. They will replace itnfor free because of a service recall. I got mine for free months ago.
Old Jun 25, 2013 | 05:05 PM
Ryan Lwin's Avatar
How did you manage that? Are you talking about Civic or Accord? Also, 1995 or 1998?
Old Jun 25, 2013 | 07:53 PM
xJDMep3's Avatar
Sounds like it could be your ignition switch or maybe a cam/crank sensor issue. check DTC's for the latter.
Old Jun 26, 2013 | 04:31 AM
95Sedan's Avatar
it sounds like a wiring problem to be honest. a short somewhere. turns the car off if you touch it just right. lol.
Old Jun 26, 2013 | 02:14 PM
mikekh10a's Avatar
96-00 civic. It was a major service recall. Look it up
Moog_enep3
Nov 6, 2013 11:03 AM
88 EF Hatch
Jun 27, 2009 06:52 PM
ixbatmanxi
Mar 30, 2009 09:28 PM
95greenlude
Dec 24, 2007 07:01 AM
b00sted4dr
Jul 31, 2006 05:14 PM
