couple more engine building questions.
Old Jun 24, 2013 | 04:03 PM
MR.johnson's Avatar
Default couple more engine building questions.
crower pros or Manley turbo tuff?
erl superdeck1 or goldeneagle?
Old Jun 25, 2013 | 05:13 AM
4cylfiend's Avatar
Default Re: couple more engine building questions.
The Manley TT I-beams have been proven time and time again. That's why I bought them for my build.
I would chose GE sleeves or AEBS. I had InlinePro install AEBS sleeves in my block and havent had any issues at all.
Old Jun 25, 2013 | 05:22 AM
AZ_CIVIC's Avatar
Manley TT rods and Golden Eagle sleeved block is what I did. I also had them O-ring it for like 100 more dollars.
Old Jun 25, 2013 | 05:23 AM
Turbo-LS's Avatar
AEBS sleeves and either rod will get it done. I would run aluminum rods personally if I didnt already have the crowers on my new engine build.
Old Jun 25, 2013 | 05:41 AM
heavy duty's Avatar
You can not go wrong with ERL great people. They will do the supper deck or dart sleeves just ask them.
Old Jun 25, 2013 | 09:01 PM
MR.johnson's Avatar
I drive my car alot on the street so im going with the steel rod. as for the block, im still in between erl and golden eagle.
Old Jun 25, 2013 | 09:12 PM
narfdanarf's Avatar
What does driving your car on the street have to do with running aluminum rods?
Old Jun 25, 2013 | 11:01 PM
Zer0_SpeedWorks's Avatar
Golden eagle block for me and my friends
Old Jun 26, 2013 | 03:14 AM
sonicivic's Avatar
golden eagle and carillo here
Old Jun 26, 2013 | 04:31 AM
luck4rmkc's Avatar
Im building GE and Manley TT, crower makes good rods as well!
Old Jun 26, 2013 | 05:53 AM
SPOOLINmatt's Avatar
Manley TT or a good AL rod.
Old Jun 26, 2013 | 08:45 PM
MR.johnson's Avatar
so, I hsve decided on golden eagle,carillos and cp. what compression is everyone liking. I was at 9.8 but you never go faster without trying something new.
Old Jun 26, 2013 | 09:20 PM
On my next build i would like to try 10.5 to 11.5cr.
Currently im on 9:1
Old Jun 27, 2013 | 03:16 AM
E Town DSM's Avatar
Golden Eagle is the way to go.
Old Jun 27, 2013 | 10:35 AM
h-duced's Avatar
I'm rocking the Carillo's
Old Jun 27, 2013 | 10:58 AM
ls_on_boost's Avatar
manley tt and ge sleeves
Old Jun 27, 2013 | 11:21 AM
boostontheD's Avatar
Are aluminum just fine with a bit of street driving? I've always wondered how long they will last with lots of just cruising? Do they have any issues with having a Ton of heat cycles ran through them?
Guess I've never heard of anyone putting them in a street car. Only full out race cars.
I myself have gone with Carrillo with the Carr rod bolts
Custom pistons 11:1 cr
And GE sleeves with orings
What power are your wanting OP?
I originally was just going to run a off the shelf piston with upgraded wrist pins but after talking to rob at TPR he advise not going that route at all.
Old Jun 27, 2013 | 11:48 AM
90blackcrx's Avatar
Goldeneagle with o-ring along with a turbo tuff rod or grp aluminum rod
Old Jun 27, 2013 | 02:27 PM
carbon fiber coupe's Avatar
running a GE o-ring w/carrillo and cps my self.! good choice!
Old Jun 27, 2013 | 02:31 PM
MR.johnson's Avatar
what power are you making? off the shelf cps or custom? thanks for the info.
Old Jul 1, 2013 | 08:50 PM
MR.johnson's Avatar
bump. anyone else?
Old Jul 2, 2013 | 04:06 PM
tpr spec 83mm (b16) w/upgraded wrist pins
motor is sitting together no start up as of yet....I did research along with good input from rob at tpr I decided to go with that setup I am aiming for 700hp
Old Jul 2, 2013 | 04:18 PM
Orangevirus1's Avatar
as much as people disagree, you can Daily with aluminum rods without issues, it isn't preferred, but it's okay.
Old Jul 2, 2013 | 04:21 PM
jdm inc's Avatar
x2 been on golden eagle sleeves for a very long time! cant go wrong!
Old Jul 2, 2013 | 04:22 PM
what's wrong with Darton's?
