Honda CR-V & Element 2WD & 4WD Element & CR-V
Gen 1 cr-v horn dead
Old Jun 24, 2013 | 10:46 AM
kiseliok's Avatar
Icon6 Gen 1 cr-v horn dead
Was honking at some not-very-good driver a few days ago - everything ok.
Then get home later that day, double click the lock, and hear no horn. WTF, but let it go.
Next day - same thing. I tried the horn from inside - dead. I've never heard of stock horns dying in any cars before - have someone else had the same issue with their V?
I haven't looked at the fuse yet - that could definitely be an issue.
Also, I need to go back to the shop that installed my fogs - they spliced them into ignition and I'm afraid they could've touched some other wires (aholes).
Old Jun 24, 2013 | 12:43 PM
Phantom240's Avatar
Default Re: Gen 1 cr-v horn dead
Horns die. It's a fact of life.
Old Jun 24, 2013 | 12:46 PM
CarGuy91's Avatar
do your interior lights and power outlet still work? a lot of times theyre all on the same fuse.
Old Jun 24, 2013 | 01:23 PM
Sticker Bomb's Avatar
It's most likely the horns have had enough, they stop working just like lights do. Check the fuse and if it's good, replace both horns.
Old Jun 24, 2013 | 03:15 PM
etmccaus's Avatar
Pretty common, actually, especially on cars that are about 10-years old and exposed to the elements. My '00 had one that was starting to go. I replaced both with a set of horns I'd had my eyes on for a while and took the old horns off -- not only were both very rusty, but the off-sounding one was filled with water, which dumped into my lap!
You can diagnose this fairly easily. Disconnect a horn, (either one will do), touch a voltmeter to the horn connector contacts, and have someone hit the horn button. If it's getting voltage, replace the horns. If it's not getting voltage, then check the horn relay (IIRC, it's in the driver's side kick panel). If that's still good, then yes, perhaps it's then time to blame the a-holes for mucking with something in the wiring somewhere...
Old Jun 24, 2013 | 04:27 PM
LDForget's Avatar
and if youre too lazy/stupid to use a multimeter, you can just grab another horn off another honda that you know works, try that one out. a test light will also work.
Old Jun 25, 2013 | 03:53 AM
Skillachie's Avatar
Old Jun 25, 2013 | 11:36 AM
kiseliok's Avatar
dick.
I bought a pair of piaas - should be here in a couple of days.
Keep getting home when it's already dark so haven't had a chance to look for a fuse. This one is in the kick panel, you say? Not under the hood?
Also, never heard of horns dying - had a few older cars before. Thanks for the responses, all.
Old Jun 25, 2013 | 06:07 PM
www.megameet.org's Avatar
Prob a fuse. I doubt both horns would die at once. (There are two for anyone that didnt know). I have one honda horn and a alarm siren.
Old Jun 25, 2013 | 07:44 PM
etmccaus's Avatar
dick.
Fuse would likely be in the block in the IP or underhood. Relay, however, is in the kick panel, IIRC. I ended up tapping into the stock horn harness up front to run a second relay to power my Fleetwood horns.
Old Jun 26, 2013 | 09:51 AM
kiseliok's Avatar
Great, thank you. Hopefully the new horns will come with good instructions and/or a new relay.
The lighter and inside lights still work. Yet to check the actual fuse though..
Old Jun 27, 2013 | 08:04 AM
blackskunk2si's Avatar
both of mine died at the same time. i metered both plugs and had ground and signal to them. bought new horns off of ebay and voila, i have horns again. good thing too because nobody could hear my finger when they cut me off.
Old Jun 27, 2013 | 08:10 AM
kiseliok's Avatar
Yep, some dummy was texting when the light turned green this morning... and I had no horn... sucks.
Old Jun 27, 2013 | 08:17 AM
nachoman's Avatar
Lol try driving in Vancouver with no horn... worst drivers in the world... I got to stop being lazy and fix mine too
Old Jun 27, 2013 | 11:35 AM
My horn sounds like a retard person talking, and yes I know that's not a nice thing to say.
Old Jun 28, 2013 | 03:56 AM
Skillachie's Avatar
Originally Posted by Sticker Bomb
My horn sounds like a retard person talking, and yes I know that's nice a nice thing to say.
Damn
Old Jun 28, 2013 | 01:15 PM
kiseliok's Avatar
So you guys were right - the old horns were complete toast.
They quite literally fell apart as we took them out.
So I gots me some new ones ... not too loud, but enough to get people's attention:
Removed the stickers for a subtle look, used the stock brackets for mounting, and stock wiring:
Yaaay for functioning horns.
Old Jun 28, 2013 | 02:32 PM
very nice dude!
Heart4Tuners
Jul 24, 2011 11:33 AM
91teg6908
Jun 22, 2010 05:50 AM
heartheVtec?
Jul 15, 2009 06:18 PM
wxy117
Mar 11, 2008 01:17 PM
hagrid
Mar 4, 2003 05:56 PM
