Starting issue
Old Jun 24, 2013 | 08:21 AM
whit3tatt3dn3rd's Avatar
Default Starting issue
So i go to start my crx this morning and it cranks like it wants to start but just cranks . thinking its an alternator issue because my battery is brand new or could it be my starter just trying to bounce things off of people?
Old Jun 24, 2013 | 08:55 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Starting issue
Alternator would not prevent your car from starting.
Starter seems fine since it's cranking the engine.
Old Jun 24, 2013 | 09:16 AM
24TEN's Avatar
PHANTOM MENACE
^Exactly. Have you done anything recently to the engine? Or experienced anything that seemed off? Generally speaking in a no start condition you would normally confirm if you still have spark/fuel/compression. Easiest to check first is spark (ground out a wire and visually confirm you have spark on all four wires).
Old Jun 24, 2013 | 09:49 AM
yeah i still have a spark and no haven't touched the engine minus looking at my air filter. and its cranking just not totally turning over.
Old Jun 24, 2013 | 10:40 AM
4drEF's Avatar
Keyboard Humorist
It's turning over just fine because you are able to crank it over with the starter.
It's just not running.
When you put the key in and turn it to the ON position (the position just before "start"), does the Check Engine Light come on for about 4 seconds and turn off?
Honda13
May 13, 2009 08:36 AM
Syed Shah
May 29, 2007 10:03 AM
alfee
Apr 19, 2006 08:15 PM
PurEvl
Dec 11, 2005 05:55 PM
rainmanef
Jan 11, 2005 08:07 PM
