Can you cut a Coolant/Water Sensor?
Old Jun 24, 2013 | 06:43 AM
ThumperDumper's Avatar
Default Can you cut a Coolant/Water Sensor?
Hey, I know this is a dumb question but here we go... I recently bought some after market gauges for my car(Coolant/Water temperature gauge) And the sensor it came with is too long. Is it possible to cut the piece to make it shorter to fit in the block?
Old Jun 24, 2013 | 09:04 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Can you cut a Coolant/Water Sensor?
Yeah sure. Most of it is just extra because they know people are going to hack it off anyway rather than get a part that fits.
Old Jun 24, 2013 | 09:26 AM
TPB's Avatar
TPB
Can you be more specific what you have as far as a sensor, maybe a pic? Water temp sensor can be mounted inline with the coolant hose which may be where it was designed to be mounted.
Old Jun 24, 2013 | 11:18 AM
tron_'s Avatar
10 Year Member
Yeah post photos. You shouldn't cut any sensor to "make it fit" and instead find the proper solution to get it to fit in it's current configuration.
Old Jun 24, 2013 | 11:30 AM
http://i840.photobucket.com/albums/z...1111/photo.jpg
The one on the left is the new one.
Old Jun 25, 2013 | 09:05 PM
Would i be able to cut this sensor? And i have read up that if i put it in the hose it wont be as affective.
Old Jun 26, 2013 | 03:04 AM
TPB's Avatar
TPB
If you're set on threading it into the block then get a threaded adapter for it, effectively shimming it.
Old Jun 26, 2013 | 06:21 AM
The Grumpiest
Why are you stuck on cutting? Do it and report back then.
Old Jun 26, 2013 | 06:54 PM
fcm's Avatar
fcm
Old Fart
Now you can't see the sarcasm in grumblemarc's post but beleave me it is there.
Sarcasm doesn't translate well in type.
You CAN NOT cut the sensor, [you can, but it will not work] get the proper sending unit to fit your engine, it's as simple as that. 94
punkracer
Jul 4, 2010 06:55 AM
Carbcivic
Mar 26, 2006 01:52 PM
Finest
Nov 19, 2003 08:15 AM
