Crome: (Missing) Pre-loaded Injector Battery Offsets (for non-stock injectors)
Old Jun 23, 2013 | 09:07 PM
SpokaneSpeed's Avatar
Default Crome: (Missing) Pre-loaded Injector Battery Offsets (for non-stock injectors)
Not sure how it happened, but I lost the drop-down menu list of injector battery offsets in the Advance Tables (CTRL + L).. (see pictures).
Anyone know why this is, or how I can get them back? Working with Crome Pro 1.6.5 w/ Fuel Tools 2.0.
Thanks.
Old Jun 24, 2013 | 03:48 PM
Default Re: Crome: (Missing) Pre-loaded Injector Battery Offsets (for non-stock injectors)
anyone??
Old Jun 25, 2013 | 01:28 PM
92cxturbo's Avatar
try changing you screen resolution
Old Jun 25, 2013 | 08:29 PM
No luck, =/. Tried several different resolutions, and also tried maximizing the Advance window, thinking it may have gotten cut off - its like its just not there anymore lol... Idk what happend.
Anyone else??
Old Jun 25, 2013 | 11:32 PM
RACEPAK's Avatar
wierd
Old Jun 26, 2013 | 06:35 AM
2000CTRSi's Avatar
The second pic has different display settings. Look at the top of the windows
Old Jun 27, 2013 | 02:04 PM
The bottom picture I actually took from Xenocron, as an example of what was once there. Lol, if its missing, it makes it a bit hard to take a picture of it
Old Jun 27, 2013 | 02:06 PM
I'm really lost though on where it went, and how to get it back! Lol, it was a handy little reference.
Old Jun 27, 2013 | 04:23 PM
92cxturbo's Avatar
What version are you using?
Old Jun 28, 2013 | 11:36 PM
1.6.5
Old Jun 29, 2013 | 02:00 PM
bump... anyone else experienced this?
Old Jun 30, 2013 | 02:14 AM
Uncle Dave's Avatar
Mine has the same problem as your Crome Pro
Old Jun 30, 2013 | 08:07 AM
GhostAccord's Avatar
Down in the bottom right corner of that window you see a pull tab. Pull that tab over a couple inches and see if that opens up to show the drop down box.
Old Jul 1, 2013 | 07:03 AM
No luck.. I've tried completely maximizing the window and the menu button just isn't there... idk what's up...? =/
Old Jul 1, 2013 | 07:22 AM
Could be something with the operating system or the window theme that you are running.
What OS are you using, Windows 7? Not sure if you can change the window theme or not. You could try and change the properties and run a classic theme????? Just throwing that out there.
Old Jul 1, 2013 | 09:44 AM
2000CTRSi's Avatar
Reinstall
Old Jul 1, 2013 | 09:46 AM
I've tried running every display resolution possible to try and see if that was the issue - no luck. I'm running Windows Vista, but running Crome in compatibility mode w/ Windows XP - Service Pack 2. (see picture)
Old Jul 1, 2013 | 09:57 AM
What happens if you remove the check/disable the "run this program in compatibility mode for:"?
Crome should work with Windows Vista.
If you right click your desktop and choose properties/ Once the display properties opens what theme are you running? You could try running XP or windows classic to see it that changes anything.
In your initial post you say that you are unsure how it happened.... Have you changed any visual settings or run any sort of new registry or file cleaner on your computer lately?
Old Jul 1, 2013 | 07:57 PM
Used to have to run it in compatibility mode (earlier versions). Ran it w/ compatibility mode disabled/unchecked and got the same result.
See picture for Theme settings.
Old Jul 2, 2013 | 08:43 PM
bump
Old Jul 3, 2013 | 05:38 AM
What about your theme is modified... aside from your desktop image. Do you have a bunch of other stuff changed around? Have you tried using classic?
Have you tried uninstalling and installing Crome?
Old Jul 3, 2013 | 03:07 PM
Nothing, just the background. Tried switching it to Windows Vista and Windows Classic, but still same result. I guess I'll try reinstalling... =/
Old Jul 3, 2013 | 03:10 PM
No cigar.... Frustrating...
Old Jul 3, 2013 | 05:00 PM
Did you do a version upgrade for Crome. And if you did, have you ever had the drop down with version 1.6.5?
Old Jul 3, 2013 | 06:22 PM
VegasInvasion's Avatar
I'm Huge In Japan
it's probably just a bad rom. try using a different one.
