99 civic si tachometer help plz.
Old Jun 23, 2013 | 07:17 PM
D.deem94's Avatar
Default 99 civic si tachometer help plz.
My tachometer works but it doesn't.. and what I mean by that is when I start the car it comes up to 2grand sitting there idling...I no its not idling at 2...and then when I go to accelerate its moves up real slow (not with the speed of the engine)..and when let off gas pedal its slowly falls back to 2.. has stock ecu. I am not a noob at driving 5 speed an don't need it but I would like it to work since I wanna restore the car.. help plz
Old Jun 23, 2013 | 07:27 PM
Former User's Avatar
Default Re: 99 civic si tachometer help plz.
Does the tach needle drop to zero when the engine is off but the key is in ON(II)?
Old Jun 23, 2013 | 08:28 PM
instrument's Avatar
Cluater sounds fuq'd, try another.
Old Jun 23, 2013 | 08:35 PM
Could also be a bad tach wire or even ECU.
Old Jun 24, 2013 | 07:18 AM
D.deem94's Avatar
No..like when I turn the engine off from idling it sits a 2 for a couple mins then starts falling back to 0...could I take a wire from dis to back of factory tach?? All gauges work expect the tachometer
Old Jun 26, 2013 | 03:38 AM
D.deem94's Avatar
Bump.
Old Jun 26, 2013 | 04:14 AM
95Sedan's Avatar
if it's an autometer gauge, to my recollection. with their gauge are different colored wires.. I believe the orange/brown wire i wanna say? ( dont remember has been 7 years)
you connect or disconnect these wires specifically to the number of cylinders. Look up an autometer schematic for your gauge. or the gauge schematic...
you messed up the wiring somewhere.
I think you don't connect eaither the brown or orange wire if you have a 4 cyl. orange only for 6 and both brown/orange for 8? i don't know. contact the manufacture.
if the gauge is responsive it's fine.
Old Jun 26, 2013 | 04:18 AM
95Sedan's Avatar
or look up a how-to im sure there's a few on this.
Old Jun 26, 2013 | 06:08 AM
Ryan Lwin's Avatar
Tachometer or any meters in your dash works with the coils in the back being magnetized at certain rate to spin the needle. Being said that, your tachometer is not good anymore because the coils are bad. You need to replace it. It's not very hard.
Old Jun 26, 2013 | 06:11 AM
grumblemarc's Avatar
The Grumpiest
If you pull a junkyard tach out of a cluster, why wouldn't the needle be on it?
Old Jun 26, 2013 | 06:13 AM
Sounds like you need to replace the tachometer.
Old Jun 26, 2013 | 06:18 AM
Ryan Lwin's Avatar
Right. I was thinking about swapping the coils only like I did with my speedometer to not mess with the odometer. My bad. Edited.
Old Jun 26, 2013 | 06:19 AM
The Grumpiest
Screw that. Just swap the whole unit. Make it easy on yourself.
Old Jun 26, 2013 | 09:02 AM
D.deem94's Avatar
I agree with u...I been seein them on the internet..
and thank u for the replys
Oreo-TeCk
Jun 14, 2011 09:22 PM
ek99
Apr 4, 2007 03:28 AM
blue99turbo
Aug 3, 2003 12:10 PM
Turbo Lude SH
Aug 7, 2002 12:01 PM
