Cam shaft position sensor CRV
Old Jun 23, 2013 | 03:46 PM
heinrichranches's Avatar
Default Cam shaft position sensor CRV
Hey guys!
My check engine light is on and it's saying that I have problem with Cam shaft position sensor. So I changed the 2 sensors already. And plugged the ecu scanner again. And the code is still there.
Im having a very bad idling on my 2005 K20 CRV already. I've been stalling on the stop light even my CRV is A/T.
Btw, my mechanic told me that I need to change my auto tensioner because it's producing a bad noise already. Is it connected to my problem wt the check engine?
Thanks guys
Old Jun 24, 2013 | 06:14 PM
Default Re: Cam shaft position sensor CRV
Anyone?
Old Aug 6, 2013 | 04:39 PM
phatrick2332's Avatar
Replace the timing chain, the tenshioner and the chain guides.
Your most likely culprit is a stretched chain which is throwing off the sync of the cam and cranks senors.
I am guessing you have a code 341?
Old Aug 7, 2013 | 03:30 AM
Yes Im getting code 341 and it's so annoying. If I cant fix it by changing those, I'll sell my CRV to a brandnew CRV again.
calcamaro
Jul 15, 2018 01:56 PM
Rex alan
Apr 11, 2017 08:36 PM
03djmAccrd
Sep 29, 2010 09:06 AM
ralfspeed
Nov 17, 2009 07:11 PM
specificcivic
12
Sep 20, 2007 05:42 PM
