NEW ECU - fuel pump stays on
Old Jun 23, 2013 | 11:33 AM
type Gendy's Avatar
Default NEW ECU - fuel pump stays on
I just picked up a 'chipped p28' after my last one blew a capacitor. I installed my chip into the new ecu and plugged it in. When i put my key in the on position the fuel pump turns out and does not go off. I confirmed i have the chip in correctly, and also tried a couple of other chips, with the same result. I put a stock LS ecu in and everything worked normally (pump turned off after a quick prime). What could be causing this ecu i just bought to behave like this?
Old Jun 23, 2013 | 12:44 PM
grumblemarc's Avatar
The Grumpiest
Default Re: NEW ECU - fuel pump stays on
Where did you buy the "chipped P28"? I'd contact the seller.
Old Jun 23, 2013 | 01:21 PM
type Gendy's Avatar
craigslist. i will shortly; just wanted to know what could cause this...bad transistor, etc? And if it could be repaired
Old Jun 24, 2013 | 04:21 AM
7rrivera7's Avatar
Fuel pump controller is "shorted". You purchased a damaged ECU.
Old Jun 28, 2013 | 03:56 AM
boosted k20's Avatar
the caps for the fule pump probably went bad and the previous owner just grounded out pin A7 internally in the ecu. I ran one of my ecus like that for a few years. no issues at all with A7 grounded out.
Old Jun 28, 2013 | 04:34 AM
7rrivera7's Avatar
There are no caps for the fuel pump so replacing them will not fix the problem. Grounding A7 works when the fuel pump transistor is toast and if you install another ECU on that car with A7 EXTERNALLY shorted, you'll damage the replacement.
Old Jun 29, 2013 | 01:27 PM
type Gendy's Avatar
Is there a way to know which transistor it is? ie. qm1, 2 or 3?
Old Jul 3, 2013 | 06:30 PM
VegasInvasion's Avatar
I'm Huge In Japan
it's QM3, and it's a pain in the *** to replace without roasting the vias. but I would make sure the adjacent pins on the chip socket aren't just bridged before you go replacing that transistor.
jdmAccord210
Engine Management and Tuning
Oct 22, 2013 11:22 AM
boostedjd
Jul 3, 2013 06:05 PM
no_rice_please
Oct 12, 2009 09:36 PM
boosted k20
Feb 9, 2009 09:15 AM
krazy
Mar 31, 2003 04:06 PM
