Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2012 coupe si race carz
Old Jun 22, 2013 | 04:49 AM
immajackuup's Avatar
Default 2012 coupe si race carz
stock 2012 si coupe
first mod at 2k miles,afe intake
install
bc coilover and rv6 2.5inch pipe came in
remove restricted down pipe
rv6 install
bc coilover install
drop statistics
Ultimate racing cat-back 3inch with secondary muffler
install
testing Acura TL wheels
between the brown,yes those two are dump rsx co workers
dump lexus co-worker
heading out
more to come.
Default Re: 2012 coupe si race carz
2010 tl
super dump 1inch off the ground
delete intake resonator which made a different with my afe intake
35 watt hid slim good ****,place all 4 ballast under headlight. 5k headlight 3k fog.
Old Jun 22, 2013 | 04:50 AM
new system came in.
kicker l7 2ohm 10inch,ported box made for l7,and mbquart onyx 1600.1 mono block
Old Jun 22, 2013 | 04:53 AM
found new home
rbc intake mani ported/bore to 70mm with zdx 70mm adapter and bore injectors for 9th gen.
[/QUOTE]
Old Jun 22, 2013 | 04:54 AM
just install my rbc and it wasn't an easy task..
3in silicone cup was a bitch to install on 70mm tb..
few tips on PRL RBC
honda bond that coolant port because it will leak slowly
before
after
rbc bore to 70mm with 70mm zdx TB
custom bracket
install twm short shifter,cage bushing,and linkage bushing.
went more low....
2012 civic ex coupe shield cover on 2012 si coupe.
22mm progress rear sway bar coupe si
Old Jun 22, 2013 | 04:55 AM
debadged and recharge a/c
clean!!
act light flywheel and heavy duty clutch,installing this bitch tomorrow.
disconnect everything.
drop sub/tranny.
smallest k-series tranny
old
new
hasport 62 bushing
drop cover
stock tranny mount
breezy
done
Old Jun 22, 2013 | 04:56 AM
car is at 15k mileage now.
Old Jul 14, 2013 | 02:35 PM
95skunkedgsr's Avatar
tastfully modded i didnt do anything on my car was considering trade in but might hold onto her longer , have you tuned the car after the rbc and bolt-ons or did you just clean up fuel maps ? have you noticed diff that would make it worth the work ? also i never missed a gear or anything i know if i shift at the top of first real fast that i can almost hear a slight grind noise , its hard to explain makes a real quick noise but it dosnt hang up or anyting , have you noticed that with your car at all , there is only 5k mils on my car had it almost a year already .. only drive to work and back and to girls house.
Old Jul 14, 2013 | 03:17 PM
Old Jul 15, 2013 | 07:27 AM
95_GSR_SEDAN's Avatar
Any tuning done yet with the flashpro for the intake, downpipe and exhaust?
Old Jul 16, 2013 | 07:06 PM
car is already tuned with stock injectors.. no bull **** etune crap.
list of cars I've beat
s2000 ap1
2012 v6 mustang
350z
g35
rsx type s
8th gen si
as for grind noise I don't know and my next mod will be 8th gen si skunk2 cold air intake.
Old Jul 27, 2013 | 01:47 PM
bump
Old Jul 27, 2013 | 02:34 PM
m_shake's Avatar
Why bump when there are no updates? This isn't a for sale thread.
Old Jul 27, 2013 | 07:55 PM
so i dont have to search for it. plus other people haven;t seen this.
Old Jul 27, 2013 | 08:30 PM
slowDB7's Avatar
im going to guess you work at a dealership?
and its lookin good, what are your plans for it other then the skunk 2 intake?
Old Jul 31, 2013 | 02:14 PM
estoyzach's Avatar
hows the speed bumps?
Old Aug 5, 2013 | 07:53 PM
Located the grind noise it's the clutch master ... It's slow like the one on 8thgens , there is already a kit out to put the older em1 cmc on the 9th
Old Aug 18, 2013 | 08:24 PM
remove cdv
Old Aug 18, 2013 | 08:27 PM
yes,acura dealership.
not getting skunk2 cai. saving money up for PRL racing turbo kit.
?? car isn't that low.
no grind noise here for me.
Old Sep 15, 2013 | 06:07 AM
got rid of afe intake for rick spec 3.5in intake.
Old Sep 21, 2013 | 08:22 AM
RippSpeed's Avatar
will that shield cover work on a 2012 sedan ??? Your build got me glue to this thread...
I'm most likely get the rbc manifold, the hondata flashpro, and intake all together...
