Slow turn over, but still starts.
Hey guys, my 92 lx coupe recently started this slow turn over sound when i turn the car on, it always turns on but this is obviously not normally behavior. I had the battery tested its rated for 700 cca and came out at 728cca, 12.78v. I doubt its the alternator as its only a few months old but it could be(no charging light indications yet). Could this be my starter or something else? Its stock starter from what i can tell. Also, it only takes one maybe two slow "Chugs" then it turns on.
It certainly could be that the starter is tired, but I wouldn't necessarily go replace it without checking other things. You might consider taking off the cables at the starter and cleaning them up to see if that helps (disconnect the battery first). Also, measure the voltage at the starter when you're starting it. The cable could be corroded or some strands could be broken inside, creating high resistance.
parts store alternators are a real crapshoot, especially autozone alternators as most don't know how to test the dual-mode that honda uses...going by recent experiences myself.
mines still an autozone...when I lightly or moderately load it it will hold up but when i throw everything on it barely puts out 12.6..at some point I'm going to have to give it back to em and man up and get a real alternator...denso reman from rockauto..which is actually cheaper than I paid for my autozone junk
All right, so car didnt turn on at all this morning. Banged the starter with a hammer and voila, problem solved until it refused to start later. Replaced and problem fixed! ty for the help
Broseph Clark
Feb 12, 2013 12:00 AM
Nocturnal
10
Aug 18, 2009 12:39 AM
aarsen43
11
Mar 19, 2009 06:31 PM
