Wait... What? a man wierd problem
Old Jun 21, 2013 | 06:21 AM
SpoonREVS's Avatar
Default Wait... What? a man wierd problem
Car: 1991 Honda Civic HB Automatic
Car was bought three days ago was running fine when it was first seen. Bought the car and drove it home... 30 minutes into the drive car turns off on the highway pull over. had to wait couple minutes and car started back up again did it twice in a 1 hour trip.
well this morning I started the car up. cold she ran good was It idle you felt a vibration so I started taking the spark plus out to see the conditions of them and turns out 3 of them had were wet with oil. clean them up put them back in and started the car. but car wont start now it just cranks fast but no start
I press the gas and crank it maybe it was flooded but nothing. car just wont start now.
has any one had this issue before?
Old Jun 21, 2013 | 07:46 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Wait... What? a man wierd problem
"wet with oil"
the top part or the actual area where the spark occurs?
Is the check engine light lit up on your dash?
Guessing ignitor or a loose ground since it stalls out and starts right back up.
Old Jun 21, 2013 | 08:47 AM
Presidential_Detail's Avatar
Detailing Mastermind
Which part of the spark plug is wet with oil?
Old Jun 21, 2013 | 10:56 AM
SpoonREVS's Avatar
there's no check engine light on. and it was the top part im guessing its the valve cover seal that need to be replace.
Old Jun 21, 2013 | 11:00 AM
You are correct. You have oil leaking into the spark plug tubes wiping out your spark. Get some new seals and clean everything up, put some new plugs in if you want and it should run fine.
Old Jul 1, 2013 | 06:32 AM
SpoonREVS's Avatar
OK I did full tune up on the car spark plugs, wires cap, rotor, gas filter fix the oil leak that the valve cover had into the spark plugs and nothing car still does the same thing. no my other option is a ECU or Distributor any other Ideas what this problem can be?
Old Jul 1, 2013 | 11:14 AM
Effingcrump's Avatar
So you changed the fuel filter?
Old Jul 2, 2013 | 02:44 AM
DCRB's Avatar
coil may have gone out, have you tested for spark? and can you hear the fuel pump priming
Old Jul 2, 2013 | 10:42 PM
rd91sib18c5r's Avatar
I also vote coil, my daughter 88 sedan did this and I had an old coil I put in
starts every time. If the coil is good next would be the igniter, harder to find
and expensive.
Old Jul 3, 2013 | 04:36 AM
99teggsr's Avatar
Checked your MPFI Relay ?
Old Jul 3, 2013 | 05:42 AM
crxin's Avatar
well first lets find out if you have spark and if you have fuel, do you hear the fuel pump come on?
Old Jul 5, 2013 | 08:19 PM
turn&burn89's Avatar
no one will believe this and its probably not the issue but if the egr control fuse is out or in your case possibly blown your car wont start. ******* crazy but its true. my 89 had that problem but idt 91s have egr or onnly automatics do
Old Jul 5, 2013 | 10:53 PM
yIhasNOlicense's Avatar
Like a guy mentioned earlier, check the main relay under the dash on the far left. If you can turn your ignition where the acc. is on and listen for the fuel pump to buzz, it may not be the main relay.
Old Jul 5, 2013 | 11:13 PM
Orangevirus1's Avatar
Check the alternator fuse, could of touched hot to ground possibly while you were messing under the hood.
Old Jul 6, 2013 | 06:28 AM
SpoonREVS's Avatar
There is spark and there is fuel car starts and idles fine with no issues... You drive the car couple blocks down and she would turn off and not start again until you wait about a minute ir so. So she is gerting fuel and spark seem like when somenting over heats it makes the car turn off
Old Jul 6, 2013 | 07:32 AM
Creator's Avatar
said twice now by others and ignored, try the main relay
Old Jul 6, 2013 | 10:20 PM
claymonthug's Avatar
sounds like a main relay. except main relays never fail when the car is running already.
illios
12
Sep 26, 2012 07:09 PM
kodyhalkyard
26
Oct 26, 2011 06:51 PM
CornFlake340
Jul 20, 2005 08:48 PM
lude12423
Mar 27, 2005 07:45 AM
fanatic
Dec 6, 2004 08:40 PM
