BrakeLights/Horn Fuse (15) keeps blowing 98 Civic
Old Jun 21, 2013 | 12:50 AM
Aaron Cayabyab's Avatar
Default BrakeLights/Horn Fuse (15) keeps blowing 98 Civic
Been having this problem since a month now,
First it started off by blowing the fuse and brake light would flash,
Check fluids added more put new fuse and the problem was solved,
One week later it, it started to blow again and it's random it would blow all of a sudden or it would blow an hr later, but brake light doesn't flash anymore.
I checked for any open wires check my bulbs and even changed out my brake relay under/back of the fuse box(Inside)
I ran out of solutions any idea guys?!
It's a Honda Civic Lx 1998
Old Jun 21, 2013 | 01:00 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: BrakeLights/Horn Fuse (15) keeps blowing 98 Civic
Have you traced all the horn wiring as well for an open short?
Old Jun 21, 2013 | 01:22 AM
Yeah I checked every wires inside and outside, But quick question if there was a short in the horn wouldn't it go off?
Old Jun 21, 2013 | 03:17 AM
95Sedan's Avatar
^ It wouldnt If there's no power getting to it because of a short somewhere.
Chances are you have an exposed wire somewhere which has eaither cracked due to age or something acidently damaged
Old Jun 21, 2013 | 11:03 AM
Ok ill double check again because I took my whole interior apart haha
Old Jun 24, 2013 | 05:55 PM
Bump I still didn't find anything only thing I found was a broken light bulb and now burn wires smell is coming from my fuse box driver side even when fuse is blown can anyone help me rewire new brake lights?
Old Jun 24, 2013 | 06:25 PM
Sticker Bomb's Avatar
Look at the wiring that goes to the trunk, because it's always bending every time to open a close it. Normally that's where you would have a broken wire touching metal or another broken wire. This is a common problem with any vehicle that has wiring going into the trunk/hatch.
jasrams
Honda Civic (2001 - 2005)
Jul 10, 2012 12:13 PM
radu
Dec 20, 2007 11:09 AM
hondaman177
Nov 8, 2007 01:08 PM
TurboEM1
Nov 19, 2005 03:28 AM
dookieface
Dec 20, 2003 12:32 AM
