help with rpm
Old Jun 20, 2013 | 07:52 PM
tollickj's Avatar
Default help with rpm
hey guys just need some help. My car has been acting pretty funny when im starting to accelerate from a complete stop as if the fuel injector's are squirting like feeling. And during the drive if im at 3,500 rpm my needle on the gauge with move side to side and will be hard to pick up... any thoughts on what that could be? I'm thinking fuel injectors could be bad but idk. Thanks.
Old Jun 21, 2013 | 03:21 AM
95Sedan's Avatar
Default Re: help with rpm
I would start by
checking your spark plugs/wires
use a bottle of water you can spray a mist on the plug wires, listen if they arc (ticking sound) if they do you need new plug wires.
manually remove the plugs & inspect them
Old Jun 21, 2013 | 10:45 AM
tollickj's Avatar
Ok ill look at it when I get home from work. I changed the spark plugs about a year ago now. But idk how long those wires have been in the car. Thanks
Old Jun 21, 2013 | 10:54 AM
sleepyaccord96's Avatar
when your rpm (tachometer) gauge acts up and moves around unnecessarily AND it bogs or runs strange i will go ahead and tell you now to just simply replace your distributor. If you are knowledgeable about the internals of a honda distributor you can replace the module but if you do not, make it easy on yourself replace the whole distributor.
Old Jun 21, 2013 | 10:56 AM
JuggerNaut-CTR's Avatar
Its usually just a icm or coil replacement that does the trick, sometimes both (like what happened to me)
Old Jun 21, 2013 | 11:06 PM
tollickj's Avatar
yeah i heard it could be that too... which sucks because i just bought a new rebuilt one...
Old Jun 22, 2013 | 02:29 PM
^ than it is no good, rebuilt distributors are trash because they aren't "rebuilt" they replace what went wrong with it and do not touch anything else...return it and pay the fee for a new one with lifetime warranty.
Old Jun 22, 2013 | 07:40 PM
tollickj's Avatar
yeah i have a warranty on it so i'm gonna do that tomorrow
Old Jun 23, 2013 | 09:58 AM
fragmare's Avatar
If you replace or remove the dizzy make sure you mark where it was with a sharpie or razor blade. If not, you're going to need to set the ignition timing when you put it back on.
boostfever
Apr 30, 2010 08:37 AM
mynameizstitch
Jun 8, 2009 07:29 AM
ty_uni_ek08
Oct 14, 2008 12:46 PM
jazz215
Mar 13, 2004 08:05 AM
inzaneN1
Jul 12, 2003 03:16 PM
