new twin disc metal on metal noise
hey guys i just recently installed a new cc twin disc in my lsv, this is my first time running twin disc and when i went to go start it yesterday it sounded like metal on metal hitting in the trans area , like something was loose. is this normal , maybe the floaters moving around. the noise starts as soon as the starter engage and stays making noise with the clutch engaged or disengaged. any info helps ill post a video tommorow
Get use to it . They are VERY noisy with your foot on the pedal . Not so much when your foot is off though . My Exedy twin is AWESOME on the strip but far from awesome on the street !
car dosent rev up, coolant temp dosent go up , basically runs like ****, i did have the battery disconnected for about a month would this erase the tune and make it run like this
I wouldn't think the battery being disconnected would cause the tune to erase itself off of the ecu.
Do you have a laptop that you can hook up to it? Was the car running fine before the clutch install?
Twins make noise but as has been said, the noise should go away when the clutch is released. I'd say you have an issue if it doesn't. Mines loud only when pressed, and does the normal squeal when released then its quiet until the next press.
ya at the track the first comment is "tires are LOW man!" and then its "you might need to check something under the hood" when you move the car.
yea im pretty sure the noise is normal but im more worried about the car not revving up....i gotta couple ppl telling me it might be wires for the ect sensor that may have gotten smashed with the trans . ill check it out tonight
Lol first time I ever started my car up with the Comp twin disc, I thought for sure I was pulling the trans cause something was wrong. Nope that's just the normal sound they make, mine has gotten quieter the more I have driven the car.
(first sound you hear is my fuel pumps, noisey bastards lol)
i just cant get it to run right , its tuff to start it takes about 3-4 times for it to start but when it does it idles like crap and dosent rev up when ever i hit the gas it just dips down
lol true
