95 Acura Integra: Parting It out, Lots of Parts
Old Jun 19, 2013 | 10:01 PM
Spawne32's Avatar
Default 95 Acura Integra: Parting It out, Lots of Parts
All of these parts are still on the car, so the rolling chassis will be sold LAST (for the sake of storing the massive amount of parts listed). I AM NOT STRIPPING THE CAR, requests for wheels, fenders, suspension components etc will not be acknowledged. If you want these kinds of parts, buy the rolling chassis and strip it yourself. Buyers for the engine and trans must provide a 50% downpayment if they do not intend to come bring cash in person. All freight costs for either the engine or the trans are paid for by the buyer.
Fully Built JDM B20 (can purchase parts seperately or entire motor)
1700 for fully assembled motor (1500 with no distributor or crank pulley)
750 for fully assembled head
850 for fully assembled short block w/ new crank pulley
400 for crower 403-2 with GE cam gears
Type-R Oil Pump
Clevitte rod bearings, oem honda main bearings
84.5mm RSMachine 11.5:1 Compression Pistons
Crower Steel Billet H Beam Rods
OEM Micropolished Crank
Moroso Oil Pan with Turbo Drain Fittings
Ported and Polished P8R Cylinder Head (33mm Intake Valves)
Crower Lightweight Steel Retainers
Crower Dual Valve Springs
3 Angle Valve Job w/ Backcut Valves
Supertech Bronze Valve Guides
Crower 403-2 Non-VTEC Cams
OBD1 Distributor w/ Accel Supercoil
New LS crank pulley
AEM SRI Intake - $50
RMF Narrow B Series Header - $200
3" Turbo Exhaust w/ Solo Performance Muffler and 3" OEM Cat - $200 (local pickup only)
OSIDETIGER 550cc Fuel Injectors OBD1 - $100
JDM MP7A Automatic Transmission Built by Precision Performance Transmission - $1500 (Includes TC and TCU)(4000 miles)
3000rpm Street Stall Max Torque Converter by Precision of New Hampton (Custom Built)
Includes Modified TCU with Shift Changers
1995 Acura Integra SE (204,000 Miles) Rolling Chassis - $1700 OBO (BUYER MUST ARRANGE TOWING)
Fully Functional AC (new ac compressor)
Remanufactured Power Steering Rack
New Tie Rods Inner/Outer
New Control Arms Front Lower/Rear Lower
Adjustable Upper Control Arms
KYB GR-2 Struts w/ H&R OE Sport Springs
Falken ZE502 Tires
Brand New Alpine Headunit prewired to the trunk for an amp
Recaro Rep Seats w/ Bride RO Seat Rails
ClockPod Gauges (AFR and BOOST)
Innovate AFR Gauge Included
Viper 2 Way Alarm System
Brand New Battery
Has minor rust spot on the drivers side quarter that needs to be repaired, otherwise completely rust free elsewhere. Body needs some TLC as its been beat to hell since it was repainted in 09, dings, dents etc.
Old Jun 20, 2013 | 09:16 AM
Spawne32's Avatar
Default Re: 95 Acura Integra: Parting It out, Lots of Parts
motor and trans getting pulled next week
Old Jun 20, 2013 | 05:08 PM
Spawne32's Avatar
need to find a buyer for the motor
Old Jun 21, 2013 | 01:03 PM
Spawne32's Avatar
bump
Old Jun 22, 2013 | 06:01 AM
Spawne32's Avatar
bump
Old Jun 22, 2013 | 07:00 AM
TheShodan's Avatar
Moderator
Good, reliable seller. No Bullshit games. You want parts, you got money... DONE.
Old Jun 22, 2013 | 02:13 PM
Spawne32's Avatar
thanks for the bump
Old Jun 23, 2013 | 05:29 PM
Spawne32's Avatar
bump
Old Jun 24, 2013 | 06:51 AM
Spawne32's Avatar
updated the list
Old Jun 26, 2013 | 09:45 AM
Spawne32's Avatar
bump
Old Jun 26, 2013 | 07:35 PM
goldhatch94's Avatar
what did it run with that auto set up like that?
Old Jun 26, 2013 | 07:43 PM
Spawne32's Avatar
14.6 on 5psi with the M45
Spawne32
Jun 28, 2013 10:07 AM
2000r#0283
Dec 12, 2010 04:57 AM
2000r#0283
Dec 11, 2010 02:05 PM
egsr6
11
Apr 4, 2007 11:42 AM
vti2
Jun 13, 2004 12:18 PM
