Fcs fuel cell filler hose.
Old Jun 19, 2013 | 06:38 PM
boostontheD's Avatar
Default Fcs fuel cell filler hose.
Just installed my fuel cell. And it says everywhere that the stock filler hose is to be reused.
Well that's impossible. Even on there site it shows a picture of a hose that's def not a stock hose or at least it doesn't look like my factory one.
What is everyone else using? Is there a hose that anyone is just buying from a parts store and trimming to fit? If so what make and model car is the hose from that you have used.
Thanks
Old Jun 19, 2013 | 07:01 PM
vavoom's Avatar
Default Re: Fcs fuel cell filler hose.
There is a napa hose part # dont remember but if you contact Jason park or any of the retailers they should be able to help had the same problem with mine.
Old Jun 19, 2013 | 07:18 PM
Thank you sir. If he gets back with me with a part number il post it up for people for the future need to knowers
Old Jun 19, 2013 | 07:41 PM
h-duced's Avatar
http://www.superstreetonline.com/pro...rol_solutions/
Old Jun 19, 2013 | 10:43 PM
MR.johnson's Avatar
let me get you the gates number. much better than that **** hose in that article.
Old Jun 20, 2013 | 12:06 AM
SLIM NOTHING's Avatar
I believe Jason parks offers the filler hose now as well. Contact him he will hook you up.
Old Jun 20, 2013 | 02:16 AM
fukenboostin's Avatar
Icon2 Re: Fcs fuel cell filler hose.
napa part number is 8484
That is the gates hose, part number 21794 napa part number 8484.
I just did this install a couple of weeks ago, stock one wouldn't work.
The above listed worked perfect.
And used a fragola performance 45* -6 push lock fitting for the vent hose
Old Jun 20, 2013 | 04:17 AM
MR.johnson's Avatar
the number in the article is a radiator hose. I wouldn't run that rubber with e85.
Old Jun 20, 2013 | 04:21 AM
In the article it's showing 21794 on the hose. Assuming that's that gates belt?
Also I don't plan in running e85 so I don't think I have much to worry about.
Old Jun 20, 2013 | 04:23 AM
MR.johnson's Avatar
ok, I guess you got it under control then.
Old Jun 20, 2013 | 05:35 AM
I was thinking about that aswell, but figured since fuel is not constantly sitting in it, it would be ok. What hose do you suggest?
Old Jun 20, 2013 | 10:36 AM
MrParks's Avatar
I've used that same hose in my tank for over 3 years now all we had run in the tank was e85/ftw now. No problems. If you do run ftw it is recommended that you switch to our aluminum filler kit. If you email us we can answer these simole questions easy without hassle. Info@fcsfab.com
HndaOwner
Mar 8, 2016 04:14 PM
Apex1972
Jan 27, 2008 02:37 PM
crxpwr1
28
Jan 24, 2007 06:47 PM
T3T495GSR
Apr 22, 2003 05:43 AM
