91 sedan signal/marker light stays on
Old Jun 19, 2013 | 07:17 AM
dubyas1989's Avatar
Default 91 sedan signal/marker light stays on
I just picked up a 91 DX sedan for a dd and noticed last night the pass side signal/marker/corner/whatever light stays on even when lights are off and key is off it doesn't blink it just stays on, what's goin on here?
Old Jun 19, 2013 | 09:03 AM
zrickety's Avatar
Default Re: 91 sedan signal/marker light stays on
It's probably the ICU behind the fuse box. You will need to have an electronics shop repair it or find a used one.
If you're lucky, you can rewire the corner light to work with the bumper light.
Old Jan 30, 2017 | 03:20 PM
nitro20%'s Avatar
i know this is 3 years old..but wireing the marker lights to the bumper lights..will this work..did this work..i have a 91 civic sedan lx and the front fender amber marker lights will not work....both sides...but everything else works perfect.
Old Feb 2, 2017 | 06:31 PM
~sp33~'s Avatar
EFB055
The park lights? They're not supposed to flash. Does the wiring have power when your light switch is on? Does the ground wire ground to the chassis?
Timothy Yhtomit
24
Nov 18, 2021 05:05 PM
efsedanpimp
Lighting
Jul 17, 2015 10:42 AM
xmrxnguy3nx
Jul 19, 2009 11:23 AM
Bone Stock
Audio / Security / Video
Sep 9, 2005 08:01 AM
