Transmission & Drivetrain Gearboxes, Differentials, Clutches
Will an '88 - '91 D-series cable LSD fit '92 - '00 D-series hydro trans?
Old Jun 17, 2013 | 10:34 PM
deevante1's Avatar
Default Will an '88 - '91 D-series cable LSD fit '92 - '00 D-series hydro trans?
i have just aquired a CRX Si trans with a quaife diff installed into it...i also am currently driving an EJ1 civic with an S40 trans on my Z6...my question is...would i be able to take the quaife out of the crx trans and install it into my S40 trans and if so what else would have to be done to it...shims/bearing wise...?
Old Jun 18, 2013 | 10:42 PM
Aquafina's Avatar
Default Re: Will an '88 - '91 D-series cable LSD fit '92 - '00 D-series hydro trans?
If it is a B000 S40 then yes. Look next to the fill plug for the casting code. It will be A000 or B000. Make sure you change the ring gear. You'll need to check the diff shim clearance.
Old Jun 22, 2013 | 02:23 AM
deevante1's Avatar
Thank you very much...clears up alot before i go and take my trans off and i cant use it...ill check to see whic casting code is on it...
Old Jun 22, 2013 | 02:26 AM
deevante1's Avatar
sorry but change the ring gear...meaning a NEW S40 ONE...or take the ring gear from the CRX trans...sorry for noobish question...just wanna cover all my bases...
Old Jun 22, 2013 | 10:41 AM
Aquafina's Avatar
Ring gears and countershafts are matched sets and need to stay together due to wear patterns. Remove the L3 ring gear and use the S40 ring gear when you put the LSD in the S40 trans.
Old Jul 12, 2013 | 10:27 PM
deevante1's Avatar
thanks alot for your help...i just checked the trans and unfortunatly its a PL3/9000...
so i guess it wont work on my S40 trans...what a bummer
Old Jul 13, 2013 | 03:26 AM
Aquafina's Avatar
Sorry. Cable 40mm will be 3000/6000/9000 so the LSD will work in your hydro trans.
Old Jul 22, 2013 | 12:15 AM
deevante1's Avatar
Thanks for the heads up...very much appreciated...
Honda Bull
Mid-Atlantic (Sales)
Sep 25, 2010 11:20 AM
Honda Bull
Sep 25, 2010 11:19 AM
Masta
Aug 24, 2006 06:22 AM
