D16A6 Block Questions
Old Jun 18, 2013 | 12:28 AM
Purfect's Avatar
Default D16A6 Block Questions
I was wondering what Head would fit on a D16A6, I thought i read somewhere that any D-Series would work as long as its from the same Year
but Would a D16Y7 head on the A6 block?
The only reason i say Y7, is cause i have it laying around unused..
I'm not wanting to make any one research just if you got it on the top of your head. id appreciate it.
Old Jun 18, 2013 | 12:42 AM
jbpnoman's Avatar
Default Re: D16A6 Block Questions
A D is a D, they're all compatible. The ZC is the only exception to the rule.
Old Jun 18, 2013 | 03:44 AM
JuggerNaut-CTR's Avatar
Just to clarify, he's speaking of the dohc zc.
Old Jun 18, 2013 | 06:49 AM
24TEN's Avatar
PHANTOM MENACE
And to clarify a bit further, all 88-00 SOHC D-Series heads/blocks are interchangeable. Most forget that the 1st generation Integras have D-Series also but have more in common with said DOHC ZC. Also 01-05 D-Series do not share the same oil drain locations so those are not a bolt on affair either.
Old Jun 18, 2013 | 07:31 AM
Purfect's Avatar
Thanks guys.. I figured D is D.. But i wanted to confirm.. Now to con my brother into giving me his Head..
Since his block spun a bearing.
remoer
18
Jul 21, 2007 09:26 AM
B18C1_CRX
Jul 10, 2006 12:09 AM
illcrx
Jun 1, 2005 08:35 PM
the jdmchop
Feb 3, 2004 10:12 AM
Xgen
Jan 13, 2004 09:32 PM
