retard the timing on my junkayard turbo setup?
Old Oct 24, 2002 | 05:08 AM
red civic standard's Avatar
Default retard the timing on my junkayard turbo setup?
In my crx, i will be doing a mitsu 14b turbo with modified Starion intercooler running 8 pounds. fuel will be managed with an inline fuel pump and a 12:1 FMU. I plan on using colder plugs. Do I need to retard my timing?
Old Oct 24, 2002 | 05:09 AM
Elite Hatch's Avatar
Default Re: retard the timing on my junkayard turbo setup? (red civic standard)
I would...retard it to like 12 degrees
Old Oct 24, 2002 | 05:57 AM
Default Re: retard the timing on my junkayard turbo setup? (Elite Hatch)
what is stock? 14 degrees +-2. So, you're saying retard it 2 degrees?
Old Oct 24, 2002 | 06:21 AM
20lb.teg's Avatar
Better yet, don't loose your down low power buy my Brand New unopened Universal MSD BTM and you can have your retarded timing and good low end power... Once again my BTM has never even been opened (still in original twisty ties never been unraveled...) I opened the box flap to take the picture but everything is still sealed... here is a picture of it
(It's on the top right...)
Hope this helps.
Later,
Sean C.
Old Oct 24, 2002 | 06:47 AM
1.8T_EG's Avatar
Default Re: retard the timing on my junkayard turbo setup? (20lb.teg)
... how much for the btm?
Old Oct 24, 2002 | 07:21 AM
20lb.teg's Avatar
Default Re: retard the timing on my junkayard turbo setup? (1.8T_EG)
PM me so we don't take away from this thread, but I was thinking like $200 shipped. But anyone with an offer, PM or email me with an offer.
Later,
Sean C.
Old Oct 24, 2002 | 08:02 AM
Im not saying to retard cam timing. But to retard the timing with the distributor. The only thing I hear about the BTM is it retards too much for amounts of booost
Old Oct 31, 2002 | 06:23 AM
20lb.teg's Avatar
Well, actually that's the beauty of the BTM, you don't retard 8 degrees ALL THE TIME...you can set it for 1/2 a pound per pound of boost so that when you're running 4 lbs you would be retarded 2 degrees. It has a fully adjustable **** that retards your timing per pound of boost. and I have seen people set it for 1/4, degree. 1/2, 1, 1 1/2, 2, 3, etc... you can adjust it any way you want so if it's retarding it too much just twist the **** a little bit and it's all good! : ).
Later,
Sean C.
dominate9
Dec 4, 2003 05:05 AM
DsMWookie
Sep 5, 2003 11:39 PM
red civic standard
Oct 25, 2002 05:33 AM
echo999
May 19, 2002 02:28 AM
