92 Accord f22 parts fit 92 Prelude?
Old Jun 15, 2013 | 08:30 PM
snoopaloop986's Avatar
Default 92 Accord f22 parts fit 92 Prelude?
i have a f22 non vtech accord has been sitting forever, timing belt broke and fried rings but it has a lot of good parts on it such as distributor, water pump, intake mani. It also has a spoon header. I just bought a 92 prelude and i would like to throw the header on it if it will fit but i havent got a chance to go check it out and see if it will be a direct swap. does any one know?
Old Jun 15, 2013 | 09:44 PM
1funryd's Avatar
Default Re: 92 Accord f22 parts fit 92 Prelude?
F22a1 or F22B?
The F22b is the same as the H23a1 which are DOHC's
F22B:
H23a1:
But the F22a1 is a SOHC:
Old Jun 15, 2013 | 10:27 PM
jwarren1904's Avatar
If its an f22a1 then yes. To my knowledge the f22a1 in the 92 accord and preludes are the exact same. I could be wrong
Old Jun 16, 2013 | 05:02 AM
I have the single cam non vtec in both cars so I thought they should be Identical from what I read the only difference is the prelude has a more aggresivly tuned ecu
Old Jun 16, 2013 | 07:18 AM
BergRacing21's Avatar
yeah they should be identical as long as they're both single cams. 90-93 accords came with the F22A motor. Along with the 92-96 Prelude S has the F22 so as long as there both single cams you should be able to swap parts no problem.
Old Jul 11, 2013 | 08:53 AM
brownzor's Avatar
But can a accord92 f22a6 soch tranny auto go in a f22z6 auto prelude 98
Old Jul 11, 2013 | 11:08 AM
tclmember's Avatar
Yes sir. F and h series trannies usually all bolt up.
Old Jul 11, 2013 | 07:35 PM
brownzor's Avatar
Even if it's tip tropic? Just have the tip tronic not working?
Old Jul 11, 2013 | 08:41 PM
MAD_MIKE's Avatar
MM Gruppe B
The 90-93 and 94-97 Accord trans are of the same family as the 95-97 Ody and 91-96 Preludes. '97+ ATs are like the later 98-02 Accord trans, that employ additional pressure sensors, and lacks the throttle cable.
I have not read of anyone backdating a newer Accord or Prelude with an earlier AT to replace the troublesome later model units.
Old Jul 12, 2013 | 11:18 PM
Thibis's Avatar
Ist it possible a Tranny of Accord Sohc (90-93) in a Prelude dohc? Or it isn't plug an play?
Or is better buy a Accord 94 Tranny for a Prelude 95 h23?
Have a why that can I see which Tranny is it? Has in it the the code Tranny? If yes, where?
Regards
snoopaloop986
Feb 19, 2014 11:56 PM
WhiteOnRice
Oct 3, 2006 05:35 PM
bigpoppa15
Aug 15, 2004 06:35 PM
Eg6_JDM
May 4, 2002 10:48 PM
