92 eg will not start or crank
Old Jun 15, 2013 | 02:31 PM
miked123's Avatar
Default 92 eg will not start or crank
What's up guys.
Okay so I got a 92 eg with an f20b swap in it.
I was drivin home the other day on the highway an shifted to fifth with a little grind and then the car just started to rev without it getting power so I coasted to the side if the road an on my way the car just shut off and would not start back up. Since then I have changed the timing belt because it was shot. It didn't snap but it was missing some teeth. The timing was set perfect by the way. After that was changed I went to try and start the car but it did not crank at all. The fuel pump kicks on but the cr doesn't even try to start. I had my starter checked the other day and it work fine. Prior to me coming home when it all happened the car wouldn't start either so me an my buddies pop started it and it ran fine. This is my only car and would like to figure this out ASAP. Any help you guys can give me would be great
Old Jun 15, 2013 | 02:38 PM
n/a2boost's Avatar
Default Re: 92 eg will not start or crank
Check to see if your getting 12 volts to the little wire on the starter solenoid. It could be a bad connection,bad fuse,bad relay or bad ignition switch.all so check and make sure your grounds are good and clean.
Old Jun 15, 2013 | 02:44 PM
miked123's Avatar
Yea I checked the grounds and they are good. I'm going to check the wire on the starter when my cuz gets home. But would this also explain why it shut off on me ?
Old Jun 15, 2013 | 02:57 PM
n/a2boost's Avatar
Not sure why it turned off on you.
Old Jun 16, 2013 | 04:53 AM
axis11's Avatar
Timing messed up, that should be enough to cause the car to stall and not start back up.
Your starter issue is a separate problem. Continue troubleshooting the starting circuit.
Old Jun 16, 2013 | 03:34 PM
Crashmaster91's Avatar
I agree with the timing.
If you were having problems with starting before, but it bump started, check to see if your clutch pedal still has the little rubber piece in it that hits the switch. My friends eg just did that to him about 2 weeks ago. We just looped the wires and it fired right up.
Old Jun 16, 2013 | 04:59 PM
sexyblack973's Avatar
Check the black and white wire that goes from the left side underneath the dash to the engine bay. If you see the inspection sticker your in the right place now,now look down and you will see sum plugs if you look down they will be going to the cabin of car. Check them. Good luck . I was not getting any crank.
shogun88
Feb 28, 2012 11:28 AM
8049710
Sep 24, 2009 05:05 PM
bsballboyjk
Mar 17, 2008 11:44 AM
vtec420kingH22
Nov 17, 2006 07:39 PM
