ignition issue
my car won't stay running after i start it unless i hold the key forward all the way. i can let it back enough to make sure the the starter isn't being turned but i'm wondering what would be cause this cause it's starting fine and it runs fine if i do that but i don't want to have it rigged. i'm thinking maybe the ignition switch? if there is one in hondas but i'm not sure thanks in advance.
also, it's a 94 eg coupe stock.
I guess I'm not sure what you're saying. So obviously it will continue to turn over if you stick the key on START...lol.
Does it ever actually RUN, or is it just turning over??
coil's fine
misternguyen
17
Nov 15, 2008 11:45 AM
DangBruhY
May 14, 2004 03:35 AM
