Vtec Solenoid cracked.
Old Jun 15, 2013 | 10:13 AM
VTECwalka's Avatar
Default Vtec Solenoid cracked.
Well a couple days ago my car was losing oil really quickly(I have always had a small leak but could never figure out what it was) I had work so there was nothing i could do at the time.
Drove to work and on the way there white smoke was coming up from under my hood at stops. I had just put more oil in it and i knew it was oil burning so i thought i did something stupid like leave the oil cap off or something so i pulled over.
Popped the hood and the oil cap was on. (lol) but i figured out why i was burning oil, Oil was gushing out from the top part of my vtec solenoid, But only in one area. Not like all the way around it. Figured the gasket might have blown. Went to a honda dealer ordered the 3 new gaskets. took the solenoid off the engine then started taking it the rest of the way apart the gaskets where not broken or anything but really dried and hard, replaced the gaskets mounted the bottom part of the solenoid to the engine with snug tightened bolts then started to put the top part on. got the 3 bolts in started tightening them and the solenoid cracked and broke off...
Right where it was gushing out oil is where the crack started. Not sure if it was me that tightened it too tight or it was infact the solenoid itself was bad
Does it take much to brake them? I still had a little more room to turn without actually putting weight into it.
Either way, I need a new one. I have all the gaskets now(not sure if i should even replace the gaskets on the used one i get don't want to brake that one too ) Where should i go to find one? I work tomorrow and all next week so i would need to get one ASAP junk yard my best bet?
Old Jun 15, 2013 | 10:28 AM
mikekh10a's Avatar
Default Re: Vtec Solenoid cracked.
at least in my area, vtec hondas usually get torn apart pretty fast in the junkyards. so you'd be lucky to find a vtec solenoid there.
i'd say look really hard for people on the forums or classified ads parting out THEIR motors.
Old Jun 15, 2013 | 10:48 AM
B_Swapped93's Avatar
ebay you can find used ones on there for pretty cheap. or if you want to be cool skunk2 sell their own VTEC solenoid(mad VTAK powerz y0). they're only supposed to be hand tight or just over so yes I can see how you may have cracked it.
Aaron_Wayne17
Honda Civic (2001 - 2005)
Oct 28, 2013 04:33 PM
allmotaR
Oct 20, 2010 09:12 AM
hybrid1990crx
Aug 12, 2005 10:41 AM
ArizSun21
May 23, 2003 05:57 AM
