94 Honda Accord JDM H22A swap questions?
Hi,
so i have a jdm H22A and im putting it in my 94 honda accord ex
we are curently at the process of fitting the wireing harness to the engine (f22b1 harness to H22a motor)
i realized that the ecm i have has three connectors and my stock ecm has only two but the two stock connectors fit in the 2/3 connectors on the new ecm is this ok?
also the orginal prelude wiring to the ecm has alot more pins going into the ecm what should i do?! i know i have to hook up a knock sensor but are there other wires that need to be swapped?
i was never aware of this situation when it came to swapping ecm and harness all i was aware of was the knock sensor connection
i will post pictures later there on my phone right now
Its the p13, im prity sure its a JDM p13 so i dont know if that makes a difference.
Biggest concern is on the p13 connectors theres alot more wires going to the ECM then the acoords connector. isnt this going to cause problems with the ecm? becasue it wont be sensing certain componets i thought this was mainly plug and play.
So just to let everybody know i was wrong... i have a P0F ecu not a P13
came across a thread talking about it so i think im set on what to switch and what not to switch
it looks like theres only two pins i have to switch for the ecm to work properly i believe its pin A6 with A11 (not positive on that)
so i will give it a try once the engines ready to go and post back
Hahaha! wow well that makes alot of sense lol its weird how the plugs are the same even though its not the ecm. well thanks guys! haha im new at swaps and ive never had to get to my ecm so i never would of known
SettleMoore
Jul 19, 2015 05:35 AM
jbhonda2004
Apr 6, 2005 09:28 AM
