Honda Accord 95 DX cranks but no start
Old Jun 15, 2013 | 06:48 AM
DjFML001's Avatar
Default Honda Accord 95 DX cranks but no start
As the description says Been trying to fix this for about a month... It cranks but it wont start, here's what I've done so far.
Start no spark changed ecm/ecu and main relay now it has spark...
Engine floods and main relay goes haywire and buzzes like crazy this happened after changing the main relay and ecm/ecu.
I did an engine swap same F22B2 engine, didn't bother changing too much but the motor mounts since basically everything else was perfectly fine.
Now I am going crazy going nearly bald trying to research what my problem is.
If you need more info I'll tell you if I missed anything.
edit: The buzzing happens when I turn the car off the the accessory after taking it off from ign1.
Old Jun 15, 2013 | 09:24 AM
DjFML001's Avatar
Default Re: Honda Accord 95 DX cranks but no start
Anything? Going crazy here >:
Old Jun 16, 2013 | 06:33 AM
DjFML001's Avatar
guuuuuyyysss
Old Jun 16, 2013 | 07:04 AM
Lost Again's Avatar
Check the timing marks, be sure the firing order is correct.
If I'm reading this correct - you do have spark, the fuel injectors are working.
For grins - double check the main ground (g101). What are the color of the three wires on the map sensor?
Old Jun 16, 2013 | 08:45 AM
DanInOttawa's Avatar
Did you use a new OEM relay? A wrecker part? One that's been re-soldered?
Old Jun 16, 2013 | 08:51 AM
DjFML001's Avatar
Brand new relay. I re-soldered the old one but no luck, and got a new one. As for the MAP sensor wire colors I'd have to take a quick look.
Edit: The wires are two Yellow/White and one Green/White
Old Jun 16, 2013 | 10:13 AM
If the relay is brand new, have you tried putting a different ECU in to see if the same problem happens?
You say that it started after you changed your ECU and relay, if the relay is new, maybe it's something with the ECU?
Old Jun 17, 2013 | 05:26 PM
DjFML001's Avatar
Ohh crap, I forgot to mention there was smoke coming from under the steering column.
Old Jun 18, 2013 | 03:49 PM
Lost Again's Avatar
That is a big piece of info to leave out......key to on/posII - check voltage on the BLK/YEL wire going to dist.
Old Jun 19, 2013 | 12:05 PM
DjFML001's Avatar
Yeah, sorry about that, i'll check on that in a bit and put it here.
Old Jun 20, 2013 | 11:59 AM
DjFML001's Avatar
Here's the situation today, I had checked out the black and yellow wire, it has power 12v (after charging my battery), all of the wires are also getting power, I have the fuel injectors unplugged for the sake of my engine not to get flooded with the fuel injectors are staying open and flooding the pistons... The relay still gets buzzy after taking the key from on/posII.
Any information I can answer.
Old Jun 21, 2013 | 07:22 AM
Lost Again's Avatar
The ground point (g101) was?
What are the color of the three wires?
Old Jun 21, 2013 | 04:05 PM
DjFML001's Avatar
g101 Is connected (as tight as possible)
Colors of those wires are Yellow/White, Green/White, Yellow/White
Old Jun 26, 2013 | 11:25 AM
DjFML001's Avatar
Problem still not solved guys. I really need help on this problem.
Old Jun 26, 2013 | 01:29 PM
holmesnmanny's Avatar
sounds like ignition switch might be bad...take it out and look at it look if burned smell if its burned
Posted from Honda-tech.com App for Android
Old Jul 18, 2013 | 11:11 AM
DjFML001's Avatar
It's been a couple of months, I went through 3 ECM's Manual transmission. They have all been fried. What can cause an ECM to get fried?
winquest1000
Jun 30, 2014 10:10 AM
usdmEHboy
12
Jan 17, 2011 04:14 PM
hondadx92
Aug 12, 2009 07:04 PM
khurdn
Oct 5, 2005 07:06 AM
.ShawnD.
Aug 31, 2002 02:57 PM
