Misfire in Cyl 3
Old Jun 14, 2013 | 12:06 PM
stevedrum4578's Avatar
Default Misfire in Cyl 3
I keep trip the same misfire code in cylinder 3, even after tuneup, new plugs, wires, cap, rotor, etc. Any advice? I can turn a wrench but am no means a mechanic. Thanks.
Old Jun 15, 2013 | 01:40 AM
holmesnmanny's Avatar
Default Re: Misfire in Cyl 3
start with a compression test
Old Jun 15, 2013 | 02:40 AM
HondaPartsHero's Avatar
Technical Hero
Is the misfire only at idle or at driving speed as well? Could be an intake manifold leak. Usually if it gets better as the RPMS rise it indicates a vacuum leak. If it remains with the rise in RPMs it is either spark, fuel or compression issue. Also in addition ohm out your injectors to see if cyl 3 is off.
Old Jun 15, 2013 | 08:08 AM
lazlong's Avatar
I'm leaning towards a bad/clogged injector. You'll know the injector is bad when you switch injectors with another cylinder and the mis-fire follows the injector.
Are you getting any other codes?
hndriver
Jul 29, 2014 03:57 AM
ArsenMotorsport
Sep 21, 2013 08:37 AM
OrangeBoost
May 30, 2006 10:22 AM
civicgeek133
Apr 3, 2006 09:38 PM
Audi A4
May 26, 2002 10:27 AM
