How to remove '1' cylinder Head bolt head by drilling?
Old Jun 13, 2013 | 03:09 PM
faran's Avatar
Default How to remove '1' cylinder Head bolt head by drilling?
Hi Guys-
So I am trying to do a Headgasket on my 1994 Accord EX F22B1 because of overheating issues.
Long story short, I am unable to pull the head and do Headgasket because of '1' Damn bolt
I am drilling on the bolt right now with a Milwaukee drill bit and used engine motor oil as a cutting oil.
I am kind stuck now, not sure how to completely remove the head of the bolt, so I can pull the head?
Please have a look on the pictures and advice, I am kinda stump now. Because if I try to drill by using 9/16', it's not removing anything and seem like bolt head is not budging
Thanks in advance for all of your help and advice.
Old Jun 13, 2013 | 05:38 PM
boostedb20z's Avatar
Default Re: How to remove '1' cylinder Head bolt head by drilling?
did you strip the head of the bolt??? your going to have to keep drilling and go up in sizes tell the head is gone
Old Jun 13, 2013 | 05:43 PM
faran's Avatar
Yes, Head is no more there. Please see in the attached pictures.
Actual size of the bolt is 14mm, I am already using 9/16" and it seems like it's not cutting or maybe it's super slow, if I continue with this pace will finish by next year
Any tip or suggestion? Am I missing something?
Old Jun 13, 2013 | 06:21 PM
vtechjunkie's Avatar
Drill slow, use a good amount of cutting oil. 10/30 at the least.
Old Jun 13, 2013 | 07:55 PM
the head of the bolt is still there your going to have to drill the head off down to the stud
Old Jun 13, 2013 | 07:58 PM
yungmulacrx's Avatar
Then when all thats done find a way get all the metal out.. Magnet or something good luck
Old Jun 14, 2013 | 05:30 AM
HellaFab's Avatar
drill a smaller hole and slowly step up.
the head bolts are hardened... they will drill hard.
Old Jun 14, 2013 | 07:15 PM
faran's Avatar
Alright, one more thing, should I drill slowly or fast?
Because I started drilling slow and continued with slow speed, but seems like drill is not doing anything or drilling SUPER SLOW.
I am starting with a small bit and then go large with the passage of hole size to finally KILL it.
Please advise about the drilling speed, thanks
Old Jun 14, 2013 | 10:02 PM
NZXTInerTia's Avatar
You may or may not have to sharpen the drill bit, they do wear out over long periods of use. Especially with that hard head bolt. Try sharpening it, personally I would bring it to a machine shop once you're done and have them professionally clean the head.
Old Jun 15, 2013 | 03:16 AM
RickyLee53's Avatar
Your going about the drilling the wrong way. (you can tell from the small chips)
Go and buy 5 drills. Start at say 4-5mm and work up in 2mm steps.
Use a battery drill, in gear one. Go as slow as possible, pressing on as hard as you can (without breaking the drill bit). Once the first hole is drilled down into the stud, slowly increase in drill size. You won't need as much pressure at this point.
I'd go easy on the cutting oil to be honest. It'll be washing little bits down into the engine. This is my main concern. (unless your doing a full rebuild) Be super careful to get all the little bits out.
Have fun!
Old Jun 15, 2013 | 04:27 PM
turbohatch96y7's Avatar
You need a carbide bit to get that hardened steel out.
They cost about 10 bucks a piece. Grainger should have them. They're the bronze color bits. Not dewalt bits. Has to be carbide. Those regular drill bits won't do a damn thing. Ill ask my machinist tommorow about another type of bit. They run about 60 bucks a peice but cut hella fast.
Don't let the bit heat up pour lots of oil continuously.
Old Jun 15, 2013 | 08:24 PM
hondab18b67's Avatar
I had this problem once so I welded a bolt on top of the head and cracked it loose
Old Jun 15, 2013 | 08:25 PM
faran's Avatar
Thanks so much guys for helping out.
I am using lots of used motor oil, magnetic pick tool to extract all the metal shavings.
I have tried Dewalt Titanium and Milwaukee ones. Also, tried Irwin Cobalt ones but seems like I am kinda stuck, drill bit does not seem to work or its cutting super slow.
Do you know the name/brand of the carbide bit? Have anyone of you ever tried 'Rigid' brand for cutting metal??
Looking forward for a response and reply, much appreciated
Old Jun 15, 2013 | 08:36 PM
faran's Avatar
I don't have a welder, also as you can see from the pictures, I am way past that point
Any other suggestion besides welding? Prolly, drilling is only an option for me or if you have some better suggestion or idea?
Old Jun 16, 2013 | 06:53 AM
Just talked to the machinist and you want to get a full carbide steel drill bit. Not the drill bits with carbide tips.
Another thing to do is get a die grinder with a steel grinding bit. It looks like you have enough room. Grind the head of that bolt as best you can.
Old Jun 16, 2013 | 06:55 AM
Like this one http://www.amazon.com/gp/aw/d/B000PJ...sr=8-4&pi=SL75
Old Jun 16, 2013 | 07:26 AM
faran's Avatar
Thanks so much Turbo, appreciate it.
Does you or anyone else has any experience with masonry drill bits?
http://rc.runryder.com/helicopter/t3.../?p=4155052#RR
http://www.6x6world.com/forums/gener...ned-steel.html
Any feedback?
Old Jun 17, 2013 | 06:43 PM
HellaFab's Avatar
masonry bits wont do anything for you...at all.
Old Jun 17, 2013 | 09:07 PM
essex's Avatar
maybe this will help you sharpen your bits if you have a grinder or belt sander
Old Jun 18, 2013 | 10:05 AM
the_unknown's Avatar
GDD Lonely Krew
If it hasnt been said enough already, you need full CARBIDE bits, and most likely a few of them. Keep the speed slow and use moderate pressure. Chances are you have hardened that thing to the fullest and really dont have any other option. You need to let the bit cut into the metal slowly and without adding heat to it.
NO MASONRY, WOOD, TITANIUM TIPPED, PURPLE CHROME DIPPED bits are going to work on this, and method is extremely important. If this doesnt work you will need to get your car to a shop that is familiar with this. Also hand sharpening your own bits wont do the job either. Start with a quality bit and dont waste your money on junk gimmicks.
Old Jun 18, 2013 | 10:53 AM
that-guy's Avatar
wow, you have really hacked this thing up trying to get it out...as others have said, CARBIDE...its the only thing that will cut through hardened steel like that, so work from small and step up to the required size
not sure if you have tried this yet, but it looks like your bolts are standard hex head and you rounded them out, did you try using a stripped bolt socket like the one in this link? looks like you still have some slight corners left on your bolt head, so you may beable to get one of these on there and get some good leverage to break it loose
http://www.sears.com/craftsman-10-pc..._tnt=39869:4:0
Old Jun 18, 2013 | 06:32 PM
faran's Avatar
Guys, a quick update.
Thanks so much for all the help, cooperation and guidance.
Gladly, I am able to crack the bolt head and pulled the head.
faran
Jun 20, 2013 12:36 PM
faran
Jun 14, 2013 07:02 AM
tensaiwung
27
Mar 28, 2012 10:02 AM
bow tie
Nov 15, 2008 05:11 PM
